Old 06-26-2013, 02:03 PM   #1
weever82
weever82's Avatar
direct replacement 4 core for my original...
Finally got the whole engine put back together and fired up after almost a year and after I filled the radiator it has a small crack in the bottom and was pouring out radiator fluid.... Needless to say I wasn't to happy... I pulled it out a few months back and had it boiled out and painted... Must have cleaned it too much and opened up a crack or they dropped it and didn't tell me...
So I am looking at getting a replacement but worried about the brackets and having fitment issues...
Anyone know of a direct replacement that will bolt right in?
It is a Harrison 4 core with factory brackets but aftermarket shroud and a 454ci...
Thanks for the heads up.
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 06-27-2013, 08:57 AM   #2
MARKDTN
Re: direct replacement 4 core for my original... :whine:
I would have a good shop fix what you have. Yes, you can buy a new one, but a good one is spendy. These radiators will basically interchange with many GM cars from late 60s through the mid 80s as long as the width is the same. Later trucks may have 4-row in BB applications. Also vans.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-27-2013, 05:39 PM   #3
dkooi
dkooi's Avatar
I have a 4 core and a shroud I took out of my truck a few years ago that I would be willing to part with if you're interested. PM me if your other options don't work out, I'm in Chandler.
72 SWB 2WD, complete frame off resto
dkooi is offline   Reply With Quote
Old 06-27-2013, 07:46 PM   #4
Z10
Z10's Avatar
I just bought this one. Made in the USA, 2 core with 1"tubes. Much better cooling that a 3 or 4 core.
It looks nice and should drop right in.
http://www.ebay.com/itm/Chevy-Truck-...item5af0b44a53
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 06-27-2013, 10:42 PM   #5
swamp rat
swamp rat's Avatar
O ended up tearing a core passage out of my radiator with a bolt, took it to a radiator guy and he was able to clear away just enough of the aluminum fin to pinch the core shut and braze it, eliminated one passage but saved my radiator.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-27-2013, 11:13 PM   #6
mrolds88
Had to put one in my 72 years ago. Got one from a mid 70's Caddy. Worked perfect. Even had the heater hose outlet!
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 06-28-2013, 02:20 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Keep us updated when you get it.. quality and fit ... then how it works once installed and run...
thanks
Rich
1972 K5 Blazer CST Click HERE
Old 06-28-2013, 02:28 AM   #8
mcmlxix
mcmlxix's Avatar
double tap
Rich
Old 06-28-2013, 06:38 AM   #9
eagleuh1
eagleuh1's Avatar
I bought a 4-core for my 68 C20 at Autozone in Phoenix that was an exact fit. Was about $140. Very good quality made by Canadian company that makes gas tank and other car parts. Would buy another again no problem. All metal also, no plastic tanks or aluminum on this one. Good luck. Jim
eagleuh1 is offline   Reply With Quote
Old 06-28-2013, 10:19 AM   #10
Custom 68
Custom 68's Avatar
Yea, mine is working good it is the stock one but I too have been looking at aluminum ones.
Let us know how this works plus I assume it is lighter?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
