Old 06-29-2003, 02:13 PM   #1
Ishtim
Talking NO SPARK condition cured 84 silverado 305-LE9 (vin H)
With help from a another Forum user, we determined that the ESC box caused fault in ignition system. Fix: all new electronic distributor components (even though all were within tolerance except low resistance on pick up coil) and jumper the green and black wires of the 4 prong ESC module plug (at the distributor). It seems that the failure in the "sparkbox" disallows one of the transistors in the IGN module not to complete the circuit required for high voltage generation and... NO SPARK .
This was very confusing seeing that all components tested out to be within tolerance and the module tested out fine.
1984 K10 - 305 CID - 4bbl
Ishtim is offline   Reply With Quote
Old 06-29-2003, 02:47 PM   #2
1FaastC10
1FaastC10's Avatar
hmmm.... i'm having a no spark problem with my 86. im going to try a non-esc distributor and see if that fixes it.
1FaastC10 is offline   Reply With Quote
Old 06-29-2003, 03:44 PM   #3
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
The only thing left to my ESC system is the letters on the tailgate. Works great.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 06-29-2003, 07:12 PM   #4
Ishtim
I don't mean to sound like an expert on this but, try jumpering the green & black wires on the ESC plug at the distributor
if all else fails (i.e. all other components are good)!
Old 06-30-2003, 07:04 AM   #5
Mike76251
This may help,
Mike76251 is offline   Reply With Quote
Old 06-30-2003, 09:19 AM   #6
Ishtim
That's it Mike76251:
Bofore you cut these try a jumper to see if that's gonna do it.
Again I'd like to thank forum member:
TC70C10
Except now I'm outta beer!
Old 06-30-2003, 03:22 PM   #7
Mike76251
TC70C10
What......outta beer at 8:19am on a Monday morning??
That musta' been a heck of a party Sunday night if it lasted that long!
Old 07-02-2003, 08:44 AM   #8
Ishtim
Now that I'm running again it seems the factory timing setting is no longer valid. Without the knock sensor what should I run the timing at? (Was 4deg BTDC @ 500RPM).
Old 07-02-2003, 11:02 AM   #9
gldevall
gldevall's Avatar
I have done the same mod to my truck. My question is since teh ESCC is no longer used, can it along with all of the wires to it be removed?
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 07-03-2003, 01:24 PM   #10
TC70C10
TC70C10's Avatar
I don't see why not.. I've got all my wires unplugged and no knock sensor.
I just haven't crawled up under the dash yet and started pulling wire.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 07-03-2003, 03:33 PM   #11
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yep, the rest of the not used crap can be removed. You'll need to plug the hole in the firewall after removing the harness. The knock sensor is where normally you would have a plug to drain the block of coolant. If you remove the knock sensor, get a pipe plug to go back in the hole. Also, be prepared to get wet.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 07-04-2003, 05:28 AM   #12
apstguy
LED King
apstguy's Avatar
Do you know if the emissions controlled trucks have different computers than the ESC only trucks? I have an oxygen sensor and an "electronic" carb - is it controlled by the ESC computer???
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-04-2003, 09:18 AM   #13
swervin ervin
Yes, emission controlled trucks have different computers. The ESC (electronic spark control) only controlls spark knock. If your truck is computer controlled, it has a ECM (electronic control module). One of the functions of the module is to control timing too. But it also controls fuel.
Mike
1985 Chevy C-10
