Old 06-26-2013, 06:25 PM   #1
dirtracer81_2
Trying the 81-87 c10 using camaro rotor
Ok so after searching some guys said it works but I am doing it. So maybe you guys can get more info on it.
So I had 1" spindles to start out with being an 81 model frame so that did help but I went ahead and went with 3 inch drop spindles. I went online and compared bearings from a 91 camaro z28 with the performance package and a 81 c10 both were same being a light duty.
At autozone I believe the part number was 55008 for the rotor. So far I just stuck the old bearings in the hub and mounted it on the old spindle with caliper and it seems it fits just like the other side.
So as of now I beleive it will work. Hopefully in another month or so I will be able to test ride it and let you guys know how it goes. I may try to get some pictures when I get the bearings and spindles to complete it.
dirtracer81_2 is offline   Reply With Quote
Old 06-27-2013, 12:19 AM   #2
maxxxy
maxxxy's Avatar
Re: Trying the 81-87 c10 using camaro rotor
I did it on my truck as well. I haven't put any miles on them yet as it is still not driving yet, but it rolls around the shop nice
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 06-27-2013, 12:04 PM   #3
king-918
king-918's Avatar
My comprehension is off will you explain in detail?
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 06-27-2013, 12:57 PM   #4
Jonboy
Slots go on anything!
That is the easiest way to switch to the car (5 on 4.75") bolt pattern wheel. It works if you have light duty (1") brakes.
Old 06-27-2013, 01:57 PM   #5
maxxxy
maxxxy's Avatar
Every single aspect between the 1" truck rotors and the camaro 1LE edition rotors are the exact same (ie depth, thickness, tolerances, diameter, inner and outer bearings). The only difference between the two is that the camaro rotors have 5x4 3/4" bolt pattern, while the truck has the 5x5" pattern.
The only benefit to swapping the rotors is for a slightly broader wheel selection with the 4.75" pattern.
Max
Max's bagged 81
Old 06-27-2013, 02:18 PM   #6
SCOTI
SCOTI's Avatar
And.... the draw back is heavier weight on the smaller (thinner) rotor. It's a known that they will warp under harsh use; especially w/cheaply made rotors. Definitely utilize the best rotor you can afford here.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-27-2013, 08:01 PM   #7
king-918
king-918's Avatar
Okay thanks for the information
<----Christopher
Oklahoma
