06-26-2013, 07:03 PM | #1 |
4 spd shifter play
So I have a lot of play on my 4 spd manual shifter. How do I tighten it up?
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
06-26-2013, 07:18 PM | #2 | |
Re: 4 spd shifter play
pritty common issue. id put some loctite on it
"its not a hobby, It's a Lifestyle" . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
06-26-2013, 07:20 PM | #3 |
I thought that was just the way they were....kind of a theft deterant system
06-26-2013, 10:35 PM | #4 |
Pull the lever out & weld the shift pin to the lever.
06-27-2013, 08:57 PM | #5 |
X2 Yes weld the finger that rides on your shift forks to the housing on the stick where it's pinned. If it's a SM465, granny low, also check the 2 roll pins on the top of the trans. housing the shifter sits in.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
06-27-2013, 11:05 PM | #6 |
Currently Blazerless
X3, common problem on the SM465, heres a good How To article on it. http://www.pirate4x4.com/tech/billav...465/index.html
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
06-28-2013, 08:20 PM | #7 |
He's talking about up by the ball, which can need attention. But the finger can be welded also. Did mine on my NP435 and made a world of difference.
