Old 06-26-2013, 11:47 PM   #1
JellyBeanDriver
replace engine oil cooling hoses with bulk hose + clamp?
Lines on factory engine oil cooler lines are leaking like a sieve at the original clamp locations.
I've found posts online of people cutting off the original crimp sleeve and replaced the line with oil cooler hose + worm gear clamps.
Anyone here done it?
I'm thinking of trying but worried about the worm gear clamp + hose coming off. With the OEM sleeve the sleeve itself is attached to the hard line and cannot be pulled off. So the hose is being held by the tubing barbs and the outer sleeve.
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 06-27-2013, 12:24 AM   #2
Rufton
Re: replace engine oil cooling hoses with bulk hose + clamp?
I have cut the OEM crimp sleeves from 99 heater hoses and the nipples had nice barbs for std heater hoses. Some of the quick disconnects had no barbs and required more work.
I just removed the 99 oil cooler system all together; no tow, light loads, short hop city driving plus hwy driving application.
Worm gear hose clamps are pretty reliable but they make me a little nervous too. They have never failed me on the road but I've had some strip out.
I have a high degree of confidence with oetiker clamps. I've used them for years on compressed air lines with zero leaks.
Rufton is offline   Reply With Quote
Old 06-27-2013, 12:48 AM   #3
JellyBeanDriver
Thanks for the tip on those clamps.
Here's the thread that I found on using bulk hose.
Old 06-27-2013, 01:10 AM   #4
dieseldawg142
dieseldawg142's Avatar
when i changed out the rad on my '90 stepper, one of the oil cooler lines snapped ( it has about a 8" hard line coming out the rad before it changes to a hose). i flared both ends of the broken line & put a piece of 80 psi hose in between. been that way for 4 yrs now, no leaks, no problems.
when i use hose clamps, i put 2 on each end with the heads one eighty apart
dieseldawg142 is offline   Reply With Quote
Old 06-27-2013, 02:47 AM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
That's what I usually do. They crimp tighter over a longer period of Time. And easy to take off again and put back on. I do this with all the hoses on my vehicles. Any leaks go away.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-27-2013, 03:52 PM   #6
beamn7
Exactly what I did as well....
beamn7 is offline   Reply With Quote
Old 06-27-2013, 05:09 PM   #7
Rufton
How did you flare the appox 5/8" Aluminum tubing?
Old 06-27-2013, 08:37 PM   #8
dieseldawg142
^^ at first i just slid the hose over, got a block & it came off (nice mess), put just a single flare on it to give the hose & clamps a bite.
http://www.harborfreight.com/double-...kit-66534.html
this is what i have, but i didn't get it at H. freight
Old 06-27-2013, 11:54 PM   #9
Rufton
Thanks.
Old 06-28-2013, 12:50 AM   #10
JellyBeanDriver
Thanks everyone! I'm going to give it a try. May get a flaring tool to make the bubble larger first though.
Old 06-28-2013, 05:51 AM   #11
4pilgrim4
For anything critical I like to use these from West Marine
"ABA OF AMERICA Heavy-Duty 316 Stainless-Steel Hose Clamps"
They cost more, for sure, but for something like an engine oil cooler line, the cost of these clamps is 'chump change' with viewed on the back side of an engine failure due to loss of lubricant.
4pilgrim4 is offline   Reply With Quote
Old 06-28-2013, 07:03 AM   #12
BigBlocksRule
Make sure that bulk hose is oil resistant/approved for oil use...
BigBlocksRule is offline   Reply With Quote
Old 06-28-2013, 11:18 PM   #13
JellyBeanDriver
Yep.
Interesting that hose vendors hide what the max temp is of their hoses.
Had to contact Derale to get their specs (300F) of their 1/2" engine oil cooler hose.
