What's the Fastest/Easiest Way to Drain a Stock Gas Tank (62)?
Before I try and fire up the engine for the first time since assembly, I need to dump the old gas that is in my behind seat tank in my '62. What is the easiest and fastest way of doing that?
Thanks ahead of time!
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
Cluster King
![]() Join Date: Nov 2012
Re: What's the Fastest/Easiest Way to Drain a Stock Gas Tank (62)?
Does it have to be completely empty? Two ways I can think of. Get an electric siphon pump or remove the seat, undo the fuel lines and bolts holding the tank and remove the tank and stand it on its side over a drain pan. That will get all of the old gas out.
I'm sorry but I have to say it. Light a match.
Cluster King
I think I'll try to siphon it first. Thanks!
That would be a BLAST!!!! I did say "fastest and easiest"!!!
![]() Join Date: Mar 2012
Take line off at fuel pump and put into a fuel can, should drain by itself,
Hmmm, already did that, and it hardly drained at all... maybe I already was out of gas (my fuel gauge was broken before I pulled the engine).
along the same line...how would one clean tank that has been sitting for 15 yrs..
live like you are dying ![]() |
Lasher, you can take the tank to a radiator repair shop and have them steam clean it. If it's super varnished, put a couple handfulls of dice sized pea gravel in it with a quart to gallon amount of berryman's chemtool. Seal off all the holes and roll/shake the tank all around to loosen up and dissolve the varnish.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
not really wanting to spend any money on it as i plan on buying underbed tank from lmc, but i need something for now to just see if motor is going to run and drive it on and off trailer. someone had told me to use a piece of chain to put in it and shake it. being the chain would be easy to get out wiirh magnet...
#12 | |
![]() Quote:
Even used it converting my personal, 1980 Chevy S-bed pickup diesel, to 350 Olds gas engine--and it had TWO fuel/gas tanks! (I still occasionally see--and talk to--the now elderly couple who bought it from me in 1987. They claim the only thing they've done to it is re-paint it.) Never knew one to leak, and it was well-known in a small town that I was converting/selling these vehicles; surely I would have been informed! But I DID follow the directions to a TEE. Plus, these vehicles had tanks on the OUTSIDE of the cabin. NOW! Follow previous suggestion to remove the tank, stand on end, and pour it out. It is not at all a difficult task. Sam |
#13 | |
Cluster King
If that is your plan then bungy cord a gas can under the hood and run a rubber hose to the fuel pump. That will get it enough fuel to run and drive on and off the trailer. Why put time and effort into cleaning a gas tank if your not even going to use it. Just my thoughts. |
#14 | |
#15 |
Moderator
![]() Join Date: Dec 2012
It will work, that's how I got my truck. Runs fine. 3 gal tank, wired right next to the passenger upper control arm. Drilled a hole in the cap for the fuel line that goes to the pump.
#16 |
thanks ill try that.
#17 | |
#18 |
The cheapest way is to take out the tank. put a chain inside and shake it around.
