Old 06-27-2013, 09:31 PM   #1
Amr84ss
HELP!!! Starter Problem
Well went to replace my starter today, seeing how it sounds like a grinder is down there. When I got the start off I noticed that my block was cracked at the.bolt hole for the outside bolt. My question is, is there anyway to fix this in the truck or does it have to be pulled? The spot where metal is missing is cracked up both sides.
Amr84ss is offline   Reply With Quote
Old 06-27-2013, 09:46 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: HELP!!! Starter Problem
Can you post a pic of where it's cracked?
A good shop might be able to weld the crack and save it but I doubt they will do it with the engine in the truck. Wouldn't hurt to ask though.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-27-2013, 11:33 PM   #3
UP GRADE
one set closer
UP GRADE's Avatar
It can be fix. Mine did the same thing had to take the motor out. My dad new this guy that could fix it. He cut the bad part out and weld in a new piece charged me $125 and I glad to pay it.
UP GRADE is offline   Reply With Quote
