Old 06-27-2013, 11:27 PM   #1
motivman50
Question 62 v8 tranny crossmember
Does anybody know what year crossmemberI need to put in a th350? I have a 62 c10 shortbox that has a 235 inline 6 in it right know .
motivman50 is offline   Reply With Quote
Old 06-28-2013, 12:01 AM   #2
Captainfab
60-66 Nut
Re: 62 v8 tranny crossmember
Welcome to the forum
There isn't one that will bolt in except for an original '60-'62 auto trans crossmember. You will have to either fab one or modify a factory crossmember to fit in between the X-member. There are holes in the X-member where the factory trans crossmember bolted in. There is a pattern of 3 holes on each side. Member markeb01 has some pics of the one he built for his truck. Hopefully he will see this thread and post.
If you had a '63 and up, you could use one of several factory crossmembers.
Old 06-28-2013, 12:12 AM   #3
motivman50
Thanks for the info . that's strange that theres no after market stuff like crossmembers and engine mount for the 62.
Old 06-28-2013, 12:14 AM   #4
62-One-Ton
62-One-Ton's Avatar
The aftermarket hates our 60-62 frames. I dig them. Seems like theyre stronger with the giant X.
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 06-28-2013, 12:21 AM   #5
Captainfab
60-66 Nut
They were only used for 3 years, and are a little more difficult to work with when upgrading the drivetrain. The '63-'72 frames are basically the same, so the aftermarket parts have a larger potential customer base. In fact the '73-'87 frames are very similar to the '63-'72 frames also.
There are some aftermarket parts that say they will work for '60-'66, but it is not always true. Just do some checking before buying those parts. They may either not work, or require some modifying to work.
Old 06-28-2013, 01:13 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum! These threads may be of some help to you. The first deals with 60-62 V8 conversion and the 2nd deals with installing a coil spring suspension, should you have any interest later:
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
http://67-72chevytrucks.com/vboard/s...d.php?t=366828
And post #15 on this thread shows an easy way to make a home built trans crossmember:
http://67-72chevytrucks.com/vboard/s...ht=crossmember
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-28-2013, 02:00 PM   #7
robber grin
Made mine from of a side section of the original bell-mount crossmember and some plate.
Good luck and welcome to the forum.
rg
robber grin is offline   Reply With Quote
