Old 06-28-2013, 11:51 AM   #1
dsanc754
Exhaust Manifold
I am putting a 2004 5.3 V8 in my 85 pick-up and I want to know if I am going to be able to use my stock exhaust manifolds. I have heard of people having problems on the right side. I am using the dirty dingo adjustable mounts. If anyone has used these mounts on this swap.
dsanc754 is offline   Reply With Quote
Old 06-28-2013, 12:05 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Exhaust Manifold
The standard trucks style manifolds have a "bump" on them that usually hit the frame rail on most swaps. In some cases if you have a good amount of frame clearance, you can just grind back the bump to get it to fit, but I've rarely seen that be the solution. Most folks start looking at the tubular f-body manifolds, tbss manifolds, doug thorley's, or a handful of other header options that work.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-28-2013, 04:07 PM   #3
truckdude239
truckdude239's Avatar
my truck manifolds would not clear with the dirty dingo on my 71 i used trailblazer ss manifolds and they cleared perfect
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-28-2013, 11:54 PM   #4
1old67
My right side doesn't fit. I went to Competition sales today and saw some headers I'm thinking about going with. There's a set of manifolds on Craigslist that look like tbss was going to meet him tomorrow but now I'm not sure. I'm useing the same towers as your year with dd adjustable mounts
1old67 is offline   Reply With Quote
Old 06-29-2013, 07:50 AM   #5
Hart_Rod
Hart_Rod's Avatar
2010+ Camaro SS factory manifolds should work.
Hart_Rod is offline   Reply With Quote
Old 06-29-2013, 04:25 PM   #6
onequikss
onequikss's Avatar
^ yep, they fit great.
onequikss is offline   Reply With Quote
Old 08-26-2013, 12:48 PM   #7
mattcrp1
mattcrp1's Avatar
Do 2001-2 Camaro manifolds work? They have egr ports. thanks
mattcrp1 is offline   Reply With Quote
Old 08-26-2013, 01:48 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The early tubular f body manifolds fit some years, but i think the egr ports are actually what interferes with fitment.
Old 08-26-2013, 11:42 PM   #9
mattcrp1
mattcrp1's Avatar
Thanks BR3W CITY, I saw a great deal on CL for manifolds and cats. Glad I asked. There are a couple of LS6 center dump manifolds for sale also, I am fairly certain they clear.
Old 08-27-2013, 03:05 AM   #10
conman585
conman585's Avatar
+1 tbss
conman585 is offline   Reply With Quote
Old 08-27-2013, 09:53 PM   #11
Blackpony
Blackpony's Avatar
x2 on the 2010 camaro manifolds. Mine fit great, and will prolly be up for sale soon as i plan to swap in some headers.
Blackpony is offline   Reply With Quote
Old 08-28-2013, 03:35 PM   #12
Matt Cramer
Are those big block engine stands?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-31-2013, 06:56 AM   #13
onequikss
onequikss's Avatar
No, they are the stock small block stands.
1977 2wd K5 Blazer Barn Find / Survivor - 2001 5.3/4L60e
Old 08-31-2013, 08:14 AM   #14
whitels1
whitels1's Avatar
I used 99 F-body manifolds and they have plenty of clearance, although I did have to use block off plates for the egr.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-03-2013, 08:36 AM   #15
Matt Cramer
Thanks, I must have a set of straight six stands. I'm going to try to cut and weld mine to clear, as most of the ones I've seen turn up for sale are the same design.
Matt Cramer
4.8 LS build thread
Old 09-03-2013, 01:57 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Pretty sure I started with the 6cyl stands myself, I moved them forward to a new location and welded them in.
