Old 06-28-2013, 03:24 PM   #1
dsanc754
Oil Pan
Am I going to need a different oil pan for my swap? I am putting a 5.3 V8 into my 85 pick up? My truck sits at stock height.
dsanc754 is offline   Reply With Quote
Old 06-28-2013, 04:10 PM   #2
truckdude239
truckdude239's Avatar
Re: Oil Pan
stock 5.3 p[an should clear
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-28-2013, 04:56 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Oil Pan
It will fit but hang a bit below the cross member. At stock height this is not a problem to you, so mechanically the pan will work fine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-28-2013, 07:00 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Oil Pan
while you have it out, throw a GMPP LSX pan on it. then if you or the next owner wants to lower, there wont be any issues.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-29-2013, 01:03 AM   #5
crazy longhorn
Fabricate till you "puke"
Re: Oil Pan
^....that is what I opted for. For a 150 bones, it was hard to pass on(complete with gasket, tray/hardware & dip stick/tube). You loose about 1 Q capacity vs the truck pan, but gain about 1 1/4" in clearance. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-06-2013, 03:59 PM   #6
dsanc754
Re: Oil Pan
what pan did you get?
Old 07-06-2013, 08:16 PM   #7
crazy longhorn
Re: Oil Pan
GMPP Hotrod pan (basically a Hummer H-3 pan). It is complete with gasket & dip stick & pickup tube.Also windage tray . Give me a minute, Ill get the PN....Longhorn Jegs # 809-19212593....10 bones cheaper now, says ships Monday! For the Gm pn, drop the 809 off the front. My truck is lowered, but not "slammed"....if you are on bags, & on the ground, your f body pan may be the ticket , or the Holley pan....best of fun
