06-28-2013, 06:16 PM | #1 |
Engine Numbers
I believe this to be a 327 going off the numbers and websites I normally look into for engine codes but I'm not that experienced in this.
Engine # near bellhousing on driver's side - 3858180 # stamped on pad in front of passenger side head - TO4I2HC Block has draft tube, side motor mount bosses canister type oil filter. Anyone see anything different? How could I make sure?
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
06-28-2013, 07:34 PM | #2 |
Re: Engine Numbers
I could very well be wrong but..64-67 327ci 2 bolt main, 250 low HP, 300 high HP, built on April 12 at Tonawanda.
06-29-2013, 01:23 AM | #3 |
60-66 Nut
Re: Engine Numbers
If it has the 461 or 462 casting heads, that should be a 300 hp 327. I'm going off past personal experience.
06-29-2013, 09:51 AM | #4 |
Re: Engine Numbers
Yea, what are the head numbers?
06-29-2013, 09:55 AM | #5 |
Re: Engine Numbers
This is off of an engine I'm considering buying and it does not come with any heads.
06-29-2013, 11:10 AM | #6 |
Re: Engine Numbers
The HC suffix indicates that it's a 327 that came from a 67 or 68 passenger car with a powerglide transmission and was rated at 275 horsepower.
06-29-2013, 11:48 AM | #7 |
Re: Engine Numbers
The "180" casting number was only used in 1965 and 1966 all model Corvette Impala Chevelles in 250 275 300 365 375 Horse power. But your "HC" code was used for 1965 1966 1967 1968 in Impalas with 4 barrel Powerglide 250 HP. 67 and 68 used completely different casting numbers. So look for a date on the block, could be a later 1964 to 1966 casting date for the 1965 or 1966 production year.
Jon
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
06-29-2013, 01:19 PM | #8 |
Re: Engine Numbers
Chevrolet by the numbers doesn't show a HC suffix being used in 65 or 66. I guess it all depends on how you interpret what you read.
06-29-2013, 01:56 PM | #9 | |
Re: Engine Numbers
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK Last edited by 60-66; 06-29-2013 at 03:52 PM. |
06-29-2013, 05:22 PM | #10 |
Re: Engine Numbers
#1
I really appreciate everyone providing help in identifying this block. Unfortunately, the owner has not contacted me back in order to arrange for purchase so either it has already sold or something else has come up. #2 How could I obtain one of those books. They seem to be invaluable when identifying GM engines, heads, etc. My father had tons of those MOTOR books and GM 'bibles' but sadly, they all 'dissapeared' after he passed away while I was overseas.
06-29-2013, 05:35 PM | #11 | |
Re: Engine Numbers
Chevrolet by the numbers here: Chevrolet by the Numbers 1965-69: The Essential... If you search long enough you might find it cheaper. For blocks and heads though it really only covers cars and anything else that was the same as trucks. It does not cover any truck specific info or truck suffix codes.Trucks use different heads and some other parts and for that you need GM parts books for trucks, they have rear end, tranny and block numbers plus a lot of other good info. Those you find on Ebay. Try and find a print date of 1970-1975 . I have one 1983 print date that's missing info on engines for our generation of trucks that's in my 1970 and 75 print books.
06-29-2013, 05:41 PM | #12 |
Re: Engine Numbers
My mistake, they do show a HC for 65. I missed it
06-29-2013, 06:42 PM | #13 |
Re: Engine Numbers
when did they stop the road draft tube? the block casting changed then, didn't it? I thought by 65? maybe cars and trucks were different.
didn't 65 -up use a spin on filter? (I suppose that could have been changed from a spin on, but who would go back to a canister, instead?) |
06-29-2013, 07:08 PM | #14 | |
Re: Engine Numbers
07-04-2013, 11:20 AM | #15 |
Re: Engine Numbers
Could someone chime in to my other thread regarding my 66 c10?
http://67-72chevytrucks.com/vboard/s...d.php?t=582122
