Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-29-2013, 04:23 PM   #1
thepunisher
thepunisher's Avatar
Safety Switch Wiring Question
I've installed a safety switch for the new air compressor for my garage and I have a question about the ground. The box has a bridge for the neutral and the ground. The bridge is not grounded to the chassis of the box. What's the safest configuration for the ground? Should I also bridge the ground and neutral to the chassis as well or is that not necessary?
Blayne
thepunisher is offline   Reply With Quote
Old 06-30-2013, 11:42 PM   #2
_Ogre
_Ogre's Avatar
Re: Safety Switch Wiring Question
assuming it is a 220 volt compressor, it will have no neutral only 2 hots and a ground
normal hookup would use 8-2 wire to match your 35 amp fuses, those wires look a little smaller than #8
assuming you ran 8-3, just tie the white wire and bare wire together in the equipment ground lug
don't double up 2 wires in one lug if your going to be inspected
what is the amperage rating of your compressor?
shop air compressor timer
Old 07-01-2013, 08:18 AM   #3
thepunisher
Thanks Ogre for the reply. What's wired to the safety switch is 8-3. The vendor said I needed a 30 amp breaker for the compressor.
Blayne
Old 07-01-2013, 10:00 PM   #4
_Ogre
_Ogre's Avatar
what amperage is the compressor? this is the deciding factor of wire, breaker and fuse size
with a 30 amp breaker you only need to run 10-2 wire, especially with the price of copper where it is
a 50 ft roll of 10-2 is $57, while 50 ft of 8-3 runs $104. almost half the price for the correct wire size.
you should also have the correct fuses for the motor, bigger is not better
Old 07-02-2013, 11:09 AM   #5
thepunisher
The motor is 22 amps. I wired this with 8 gauge wire in case I ever got to the point of purchasing a different welder that needs a 40 AMP breaker. Obviously I wouldn't be able to run both at the same time but I'm wired to run whatever. The time delay fuses are 35 AMP fuses per Square D's recommendation.
Why would the 8 gauge wire be an issue if the breaker is properly sized?
I recognize the cost difference, I was able to purchase the wire through a local electrical supply house at $1.22 a foot (considerably less than HomeDepot). I needed 25' so it was ~$30 worth of wire.
Blayne
Old 07-02-2013, 01:49 PM   #6
_Ogre
_Ogre's Avatar
pre-planning for a welder is a good idea.
just making you aware of the wire size and cost.
Old 07-02-2013, 02:03 PM   #7
thepunisher
Awesome, thanks Ogre for the help!
Blayne
