Old 06-29-2013, 10:46 PM   #1
cwilkie
Chance
cwilkie's Avatar
Tach question
Question. The tach in my truck quit working. When I open and shut the door the tach seems to jump a little. Sometimes when I start the truck he tach will work for a second or two then stop. Has anyone had these symptoms. The tach is a reproduction. I have not done anything to the truck execept boost the battery so I may have fried the tach but it does work momentarily sometimes for a second or two.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 06-30-2013, 12:16 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Tach question
Normally the tach only has three wires to it. The power wire from the key or fuse panel. The tach signal wire from the distributor (HEI) or coil negative side (points), and the light in the tach. Make sure the tach body is grounded. The HEI connection could be loose, or the power connection might be bad. Can you try the tach on another vehicle?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
