Old 06-30-2013, 12:42 AM   #1
candrive55
clipped 1957 chev truck column angle
camaro clipped 1957 chev truck. for my steering shaft to line up with my after market steering column it looks like i would have to extend the hole in the fire wall up by 2 or more inches. (thats 2 or more inches from what you see in pics)
What other options have guys done.
candrive55 is offline   Reply With Quote
Old 06-30-2013, 01:07 AM   #2
Stepside Jim
Re: clipped 1957 chev truck column angle
Depending on what clip you used, if it's like mine, yes, I raised it up to where the angle is where the firewall meets the floor.
Mind you, the last time I posted a pic of it, there was a comment of it's danger if you get into a front crash.
I also went with the aftermarket u-joints vs the stock ones. They gave me alittle more flex at the gear box as the column gets raised.
Stepside Jim is offline   Reply With Quote
Old 06-30-2013, 01:11 AM   #3
candrive55
can you pm me the pic of it or post it up. many many thanks
Old 06-30-2013, 01:40 AM   #4
Stepside Jim
The quickest one I could find is a inside of the cab picture. It shows how high I went with it.
If I have gone about 1/2" to 3/4" lower it would have relieved alittle angle on the front joint. I also liked it high because I hope when I put the carpet in, I have a clean fit, not much cutting around the column.
Old 06-30-2013, 01:52 AM   #5
candrive55
Thanks for the pic. I am also thinking now my 2.5 inch column drop is to much. damn
Old 06-30-2013, 01:59 AM   #6
franken
If you look at some conversions the U-joint angles are insane. No doubt you can fix what's in the 1st pic w/ scrapyard parts. The cheesey factory U-joint is hurting you.
Might also consider a conversion to later model through the firewall, not floor conversion.
franken is offline   Reply With Quote
Old 06-30-2013, 06:02 PM   #7
mygirlz55
I used a steering section from a Chevy Astro after seeing it in some posts here. I have a 55 2nd series with a 77 Camaro clip. Still need to put a set of headers in before I make a bracket to mount the shaft to. It has a double joint in it that keeps the shaft at a good angle.
mygirlz55 is offline   Reply With Quote
Old 06-30-2013, 06:41 PM   #8
Coupeguy2001
Coupeguy2001's Avatar
Check out my build thread "my 57 revitalized" you can see that my steering shaft is almost straight and I went high with the column. Right to the crease.
My subframe is a "custom" G body clip.
Coupeguy2001 is offline   Reply With Quote
Old 06-30-2013, 06:45 PM   #9
Coupeguy2001
If you look at my build thread, " my 57 revitalized" you can see in post #38 that the shaft is straight. you have to go high, like to the crease.
steering box ahead of the front wheels.
Old 06-30-2013, 09:42 PM   #10
_Ogre
_Ogre's Avatar
you have a lot of column sticking thru the firewall, pull the column up 2 inches to see if it fits better
the column needs to be tight to the dash, a zero drop for maximum leg/knee room
i set my column tight to the dash, when i installed the speedo cluster i had to grind a flat on the bottom of the bezel
i used an astro/safari van column. i think the s10 is the same
stepsidejim: i think the steel dash would be your biggest concern in a front end collision
with your column that low, it looks like knee room is limited, though you can probably tilt the wheel up to fix it
shop air compressor timer
Old 07-04-2013, 10:53 AM   #11
Coupeguy2001
I was told a 30 inch column is the best length, but after I installed it, I could have used a 28 incher also.
