question on ad truck
ive heard that when you run a sb chevy in an ad truck (if you use engine driven fan) that the fan sits low on the radiator. what would be wrong with building an offset fan shroud. would that work , would it still pull enough air through the radiator. ill be using short wp. I know they make the wps that sit up higher but they are pricey. thanks guys
