Old 06-30-2013, 10:52 AM   #1
lucky71gmc
Best way to replace a front spring hanger bracket?
My drivers front spring hanger bracket on a 1972 chev 1/2 ton 4 x 4 looks like it has been worked on with a grinder and welder. The spring bracket where the eye bolt of the spring goes thru is no longer at a right angle to the frame. This is twisting or putting pressure on the leaf springs sideways.
In trying to replace a hacked spring bracket can bolts be used in place of rivets? What other procedures are necessary to secure the bracket to the frame? Br.
lucky71gmc is offline   Reply With Quote
Old 06-30-2013, 01:05 PM   #2
BigRed76
BigRed76's Avatar
Re: Best way to replace a front spring hanger bracket?
If you use grade 8 nuts and bolts you'll be fine.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 07-01-2013, 08:04 PM   #3
lucky71gmc
Thanks, spring is loading and unloading the shackles with the eyelet on a twist going thru gutters, no problems on a smooth road. Br.
