front left tilt ?
awhile ago I posted about how my truck looks to be on a left front lean from behind the right rear looks higher then left side and from the front the right front looks lower then the left side
here's what I have done so far I have replaced all cab mount bushings have replaced all front control arm bushings I swapped front springs around and rear leaf springs also I checked the frame on the front for level and it is near on perfect but I still see the same lean to the truck anyone got any ideas what to do next ? |
Re: front left tilt ?
The Chevy lean....sounds like you covered all the obvious thinks already..
Bent frame?? I think anything less then a 1/2" is probably acceptable.. I ended up shimming the body a little..no more lean. Posted via Mobile Device |
I did some more measureing and found that if I measure from the bottom bump stop to top spring support there is a difference of about 3/8th lower on the drivers side
doesn't sound like much but its visible when looking at the truck I wonder if new springs might help ? or can I cut a little off the other spring to even it out ? sounds crazy but I know its going to p**s me off |
I should mention that it has had the six cylinder replaced with a 350 v8 will this make a difference to what springs I need?
Robert Olson Transport
![]() Join Date: Oct 2002
you should get load leveler springs or cargo coils
Thanks rusty where is the best place to get them new to ths stuff and sorry for the incorrect posting I will sort supporting the forum
Hey man I put a 5" DJM lowering kit on my truck and it leaned 1/2" on the front drivers side. I checked all kinds of stuff thinking I screwed something up. I did some research on Google and found where people put coil spring spacers under the low side. I purchased one from Summit and the problem is now fixed.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
thanks have just purchased mine will let you know how it works
| Bookmarks |
