Old 06-29-2003, 08:42 PM   #1
orange72350
orange72350's Avatar
Aftermarket Intake Mainifold ???
I just bought a used performer intake manifold for my 350 rebuild project. Im running a quadrajet on this, and i have noticed some differences from the stocker. On the old manifold, there was a coil on the side by the carb with a little piece of rod sticking out of it. it has a little cover over it. this was hooked to the side of my carb. does it have something to do with the choke? can i change it over to the new manifold, or is there something im missing? a
Also, there is a stud sticking out of the manifold up by the front main water passage. what is this for?
Thanx in advance. sorry bout the stupid questions. im new at this.
Dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 06-29-2003, 08:57 PM   #2
jef5150
Inline 69
jef5150's Avatar
i believe thats an auto-choke& it works off the heat of the manifold,,,,,,,,,as far as the stud ,it probably either a place to mount an accessory,or sometimes there is a flexible metal "loom" for routing acc lines,,,,,,,next!
jef5150 is offline   Reply With Quote
Old 06-29-2003, 08:57 PM   #3
cableguy0
the coil is part of the choke the easiest way is to just get an electric choke carb and ditch the heat choke setup altogether because the performer doesnt have provisions for a heat choke
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-29-2003, 09:03 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
The Performer intake does have provisions for the heat choke, mine came with a little piece to bolt the heat coil to on the intake. I agree though, the heat choke setup sucks. I switched over to an electric choke, and it works 10x better.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-29-2003, 09:41 PM   #5
orange72350
whats involved in installing an electic choke? is it just a matter of finding ignition power and plug and go? or is it tougher?
Old 06-29-2003, 09:51 PM   #6
1971 Cheyenne
1971 Cheyenne's Avatar
the stud up front is just an accesory hole for different stuff. We put my performer on a 305 and used that hole for the alternator.
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 06-29-2003, 09:54 PM   #7
lukecp
lukecp's Avatar
You will have to get a different carb than your stock Q-jet. Later Q-jets have electric choke, or you can buy a aftermarket carb with an electric choke such as a Edelbrock, Carter AFB, or Holley. Hookin it up only takes 2 wires.....
Old 06-29-2003, 09:57 PM   #8
bigjimzlll
bigjimzlll's Avatar
the choke is called a "divorced choke"
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 06-29-2003, 10:43 PM   #9
jimfulco
I just found this. To convert a divorced-choke Qjet to electric, go here & scroll almost to the bottom:
http://www.carbs.net/quadrajet.asp
jimfulco is offline   Reply With Quote
Old 06-29-2003, 11:08 PM   #10
orange72350
i was just out looking at the manifold. the old heat choke slot is all siliconed up. i wanna order an eldebrock 600, but i need $$$, so ill have to make the divorced choke work for now!!
