Carpe manana
![]() ![]() Join Date: Dec 2010
Engine block code(s) correct for 72 and others
What are correct block codes for a 350 in 1972? My Blazer motor has two terminal letters I suspect are "C" and "E" - the motor was probably decked so these are subtle but I suspect the motor is original. Codes are located on a boss on the RH front of the block visible from the pass fender side. I have codes for K10s and K20s (they start w "T") but no K5s. For those who have original 350 4v motors in their Blazers, what are the engine codes? Mine has CA emissions equipment if that matters...thanks Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Engine block code(s) correct for 72 and others
I believe CE stands for Counter Exchange. If that is correct it could have been a warranty replacement engine.
1972 K5 Blazer Cheyenne 1966 L72 Corvette Convertible 2016 GMC Yukon Denali |
Carpe manana
Thanks! Plot thickens - I was wondering if the "T" was be decked off (TCE motor?) - curious to know what should have been in the truck (it has a TH350 tranny). Counter exchange is not something I'm familiar with - maybe that is case. All the little 4wd specific underhood parts are there: correct 4wd dipstick, bracket for AC vac pod, etc.
I just pulled this off of the Corvette Forum. A super knowledgable guy posted it.
"The "CE" block (and "CT" transmission) coding was introduced shortly after the 5/50 Powertrain Warranty went into effect for the '67 model year so the GM bean-counters could track the 5/50 warranty costs vs. the usual number of service replacement engines that were ordered by customers for normal customer-paid "over-the-counter" or "out-of-warranty" engine replacements, when it became obvious that the true cost of the 5/50 powertrain warranty was going to be FAR higher than the predictions when the program was sold to GM management. "CE"-stamped engines were supplied two ways - as short blocks, or as "fitted blocks" (block and fitted pistons, no crank or rods), the assumption being that all the bolt-on parts would be swapped over from the customer's failed engine. They started out being coded with "CE" followed by a number which indicated the calendar year they were built, and a sequence number which indicated how many replacement engines that particular engine plant had built that year, and shortly thereafter Flint Engine added a second letter digit that indicated the month built - don't know offhand if Tonawanda did this or not. The dealer ordered them from a chart that showed a part number for the engine assembly for each application so the engine would have the right internals, but this part number wasn't anywhere on the engine itself - only on a tag and label on the crate it came in. Occasionally "CE"-stamped short blocks were sold over-the-counter for various reasons in those days, but normally customer-paid service replacement engines had blank pads with nothing on them at all."
Carpe manana
The digit after "CE" is 3 - I suppose this is a '73 replacement block.....what if any impact to collectability/originality is a counter exchange block?
If it were a Corvette it would be huge, not sure about trucks. But I imagine there will come a time when matching numbers become even more desirable with these trucks as well. I wish mine had matching numbers.
Carpe manana
Thanks! The Blazer was in such good shape I couldn't pass on it for the block alone. If it's a warranty replacement motor/block from GM I'll take it over a generic replacement. When I get time I'll check the heads to see if these are correct for the K5 as per date codes...
