c10 all over the road?
Hi guys
just had some new radial tryes fitted to my c10, it used to wander the road on the old crossplys so thought id treat myself to a new set of radials, My trucks got a disc brakes and power steering off a later truck i think, the truck still weaves bad on the motorways in the tracks left by the big rigs has anyone else had issues like this? could the steering box need tightening? or worn steering arm? on the smaller roads it drives dead straight ? |
Re: c10 all over the road?
What are your toe-in settings? Has it been recently aligned?
We had a similiar problen with a vehicle we owned a while back- it had fairly wide tires on the front(55 series on 17" wheels)It would follow ruts in asphalt real bad. Never really fixed the problem, but learned about wide low profile tires, LOL! |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
tie rods?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Senior Enthusiast
The toe setting is also my first thought. The next would be a worn out idler arm. If the toe isn't set slightly inboard at rest, the wheels will point outboard at speed. Each time one side points straight ahead, the other side will be pointing outboard and tend to pull to that side. Once that side points straight ahead, the other side repeats the problem. The result is a wandering vehicle that can't decide what is straight ahead.
With a worn idler arm, the steering box tends to steer the left wheel while the passenger side wobbles around pointing wherever it wants. This can not only cause the vehicle to wander, when everything lines up harmonically it can also cause the front end to shake so hard the vehicle must be slowed down to stop the shaking (depending on how badly the idler arm is worn).
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Hi guys
have you Ever used a steering damper? If so any pics? Posted via Mobile Device |
meowMEOWmeowMEOW
Did you use a multi-piece steering shaft (or run more than one DD joint?)
If so , did you add a steering shaft brace/heim/support bearing? Mine has a little "bobble" in the steering on jumpy roads or half-lane construction situations. Its because the steering shaft angle required a multi piece shaft, and between the rag joint nd the DD joint the shaft has room to bounce. This also happens and can make the truck feel like it doesn't have a perfect center on the steering sometimes.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Mar 2005
I agree with the above comments. Have it aligned. It sounds like you've got a toe issue.
If you get it aligned, have the tech put as much caster as he can in it. Caster will help it go down the road a lot nicer, and it won't have a tendency to wander.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
did you put 2 or 4 radials on?
another source for wander is brken bolts on the steering box and or cracks in the frame around the steering box. it can crack around the bolt holes and be difficult to see. have someone turn the steering wheel and watch and see if the steering box moves. truck sitting on the ground so that there is weight on the wheels ron |
Thanks guys
think I'll get it aligned, what camber and toe in do you recommend? Posted via Mobile Device |
![]() Join Date: Feb 2013
Kinda reminds me of that country song
No Weak Links ![]() |
