Old 07-01-2013, 10:55 AM   #1
77c10
77c10's Avatar
Fuel filler question
The previous owner of my truck moved the fuel filler to inside the bed in the wheel tub. I am having trouble with the hose rubbing the tire and want to get an original filler neck for a 77 and put it in the bed side. From what I can tell, in 77 they did not come with a gas door. My question is, does anyone know how they were mounted from the factory? I am trying to figure out if it is as simple and using a hole saw and making the appropriate size hole and putting the filler neck through from the backside or is it more elaborate?
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 07-01-2013, 12:28 PM   #2
79Betty
79Betty's Avatar
Re: Fuel filler question
3 screws hold the metal piece to the bed.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 07-01-2013, 12:39 PM   #3
77c10
77c10's Avatar
So, I just use a hole saw and put a hole in the bedside and mount it?
Old 07-01-2013, 02:26 PM   #4
Stepside Man
Stepside Man's Avatar
Not exactly. In 77 the truck gas hole was stamped into the side of the bed. It was recessed into the side when it was stamped. My question is where did your hole go?
1977 K10 6ft Stepside L6
1978 C10 8ft Stepside 400
1980 C10 8ft Widebox with Uncle L6
1986 K35 Not a dually 350; 79 K20 Stripped
1973 and 1976 Chevy Truck Trailers
1995 Impala SS LT1
Stepside Man is offline   Reply With Quote
Old 07-01-2013, 02:29 PM   #5
Stepside Man
There really should be a gasket also between the filler neck and the bed. That would be very easy to make. The original filler hole has to be on the bed somewhere. I would try to recover that opening.
1995 Impala SS LT1
Old 07-01-2013, 02:38 PM   #6
77c10
77c10's Avatar
Pretty sure the PO filled it in when he moved it to the bed. I will get under it tonight and look from the backside and see.
Old 07-01-2013, 03:01 PM   #7
79Betty
79Betty's Avatar
Pretty much yea but that's the main concept
Old 07-01-2013, 03:39 PM   #8
KrazyRay
KrazyRay's Avatar
If the tank is on the driver side then the bed may not have had a filler hole as the passenger side was the factory location for single tank trucks for that year. I have a crate full of filler necks for 73-78.
KrazyRay is offline   Reply With Quote
Old 07-01-2013, 05:34 PM   #9
77c10
77c10's Avatar
The tank is on the passenger side.
