What models should I look for a BBC in?
Heading out to the local pick and pull soon and was wondering what years/vehicles I should be looking at to pick up a BBC motor? I'm not as familiar with the BBC variances as I am with SBC and LS motors.
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#2 | |
Re: What models should I look for a BBC in?
Unless you are lucky enough to have a yard that has some older vehicles, you are really only going to find bigblocks in pick.up trucks.
If you do indeed have such a place, you could theoretically find one in quite a few different cars. Of course all of the "performance" cars could have had them, but the big "boat" cars could too....even station wagons. Not a lot of help, sorry.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right.
better off on criags list man. finding bb is a thing of the past. unless its a 366 pos.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
78K & 79C Jimmys
may find it in a complete car/truck
but my firebird and olds both had buick blocks watch for the older 350 blocks,in the Buick,Pontiacs,Olds might look bigger just not bigger cubes
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Pretty much just 3/4 ton or 1 ton trucks, motorhomes, etc. All will be low compression with crap heads. Bigger trucks like C60's had tall deck motors which I personally wouldn't use.
At the body shop.
3/4 and 1 ton pickups.
" That didnt make it any newer " " Dont antique the equipment " |
Gotta watch out for 366's, they look like any other tall deck block.
Best engines generally come out of heavier vehicles - they're geared so the engine doesn't have to rev too high. 3/4 and 1-ton trucks are best candidates, bigger generally have tall deck blocks. Look at the top water pump holes into the block - it's about 1/4" on a passenger deck block, more like 3/4" on a tall deck. Plus some have double thermostats, can't miss those. If you can't find anything, let me know, we still have plenty around here. |
pick and pull yards here pull most of all the good stuff b4 they put vehicles out to the public// so most vehicles with motors still in them are non rebuildable POS
i see quite a few BBC on craigs on a regular basis what type of motor r u lookin to build?? the old school big block or new school roller injected type wood make a dif when lookin for a core for building
Your best bet is going to be a truck. GM stopped putting BBC in cars sometime around the mid 70s and I think only Impalas had them.
Look for an 87 and older truck. The 91 trucks had the Gen V motor that can only accept Gen 5 heads and has no provisions for a mechanical clutch. Gen VI motors came out in 96 and solved that issue, but the timing cover and oil pan are specific to the Gen VI, Gen V and Mark IV blocks. I cannot remember the measurement but the easy way to tell the difference between a tall deck and a short deck is to measure the distance between the top of the timing chain cover and the bottom of the intake manifold.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
Thanks for the advice/insight. I'll report back and tell you what I find.
| Bookmarks |
