Recommendations on a Fuel Tank '66 c10
So, I've looked through FAQ section 2b under mount tank. http://67-72chevytrucks.com/vboard/s...d.php?t=370496 I went through the post, looked at literately 20 different builds and styles and looks... but I can't really make out which is the best. I want to relocate the tank to back of my 1966 Chevy c10. But I have no plans on running a Roll pan or a bumper and I don't really want it stick down like the Blazer tank. I'm not sure i like how low the LMC replacement looks. also I'm not sure if these tank would allow me to still mount a hitch to the frame or not.
much later on i will eventually put air bags on the truck. though i will not be modifying the frame to make it slammed. just going to make it drop as much as it will stock. is there a smaller tank or a better solution. It doesn't need to be 20gals i mean a 15 - 16 gal or in that range would be ok. If the Lmc tank would work best for my application, or if you think it would. I think thats looks the easiest and cheapest. ill have to deal with the look. any help would be much appreciated. Seth ![]() ![]() ![]()
Seth - '66 C10 fleet side w/ '65 327 Build thread http://67-72chevytrucks.com/vboard/s...=1#post6156212 Last edited by Hemisaurus; 07-02-2013 at 02:04 AM. |
