07-02-2013, 04:45 PM | #1 |
HEI info needed
Could someone tell me what gauge the "battery" terminal wire is that runs to a stock HEI setup? In other words, would the 18 gauge wire that used to go to the positive side of the coil be ok to run to a stock, ( but not original) HEI system In my '68? Thanks.
Posted via Mobile Device |
07-02-2013, 04:46 PM | #2 |
Re: HEI info needed
I think they will work with 14 but I do 12 gauge.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
07-02-2013, 06:15 PM | #3 |
20' Daredevil (Ret)
Re: HEI info needed
Agreed..... I wouldn't even try 18 ga.
I've seen 10 ga. recommended but that's way too fat and is overkill.
07-02-2013, 09:15 PM | #4 |
Re: HEI info needed
if vou're talking about the original wire from the ignition switch to the coil ,it is a resistance wire to lower the voltage to the coil...HEI needs a full 12v via a normal wire
1970 short step c10 leaf spring 454 |
07-02-2013, 09:25 PM | #5 |
Re: HEI info needed
X2, like other brands use ballast resisters Gm built the resistance into the wire. Run a 12 gauge straight from the ignition switch out to the Dist.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
07-02-2013, 10:08 PM | #6 |
Re: HEI info needed
Start reading at post 13 in this thread. I did this and used a 12 gauge wire.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346 Post 7 in this thread gives two options. http://67-72chevytrucks.com/vboard/s...d.php?t=562034 |
07-03-2013, 09:48 AM | #7 |
Re: HEI info needed
Thanks so much guys for the quick replys, this is EXACTLY what I was looking for! My plan is to completly remove the white and yellow wires starting a the firewall connector and install a replacement (12 gauge) wire and run directly to the distributor.
My final question is: I need two parts, the crimp on terminal wire ends and the plastic connector clip that plugs into the HEI, (Batt and Tach connector)can I buy these pieces locally (NAPA, etc.) and if so, does anyone know the part numbers? Thanks for everyones help, this board rocks! P.S., The NAPA p/n for the terminal ends looks like it is #725145 but that is for 16-14 gauge wire, is there anther p/n for use with the 12 gauge wires? Last edited by Steve Cole; 07-03-2013 at 10:00 AM. Reason: forgot something |
07-03-2013, 10:02 AM | #8 |
Re: HEI info needed
you don't actually need the plastic plug...a female spade terminal fits right on the male in the distributor...just get a small asst of blue solderless connectors
07-03-2013, 10:20 AM | #9 |
Re: HEI info needed
Thanks Volksworld I may do that but I wanted to first try and get that connector to make the connection look "factory".
07-03-2013, 11:36 AM | #10 |
Re: HEI info needed
If you're going for a REALLY stock look and have alittle time to wait for it, Year One has a HEI conversion wire available that actually has the correct connectors on each end to fit into the stock fuse block in place of the original resitor wire.
https://www.yearone.com/Product/1967...c-truck/l00510 I think Classic Industries and a few others have it as well.......and I'd probably try another vendor if I was doing it again. It took three weeks for Year One to get it from just north of Atlanta (them) to just south of Atlanta (me)........so I'm not sure I'd recommend Year One as a source, but to just let you know there is a pre-made conversion wire available. I hope that helps.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
07-03-2013, 11:37 AM | #11 |
Re: HEI info needed
Steve,
If I'm not mistaken, I found the connector at a local auto electric shop. It was only a buck. I bought 2. One Brown one White.....Wanted to make sure I had one for the tach. This shop had the shell and the connector seperate.
07-03-2013, 11:49 AM | #12 |
Proprietor of Dale's Corner
Re: HEI info needed
I have purchased both pigtails from an auto parts store as well as robbed them at the wrecking yard
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-03-2013, 12:21 PM | #13 | |
Re: HEI info needed
Good luck!
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
07-03-2013, 03:46 PM | #14 |
Re: HEI info needed
Thanks Camrycurt!
07-03-2013, 11:03 PM | #15 |
Re: HEI info needed
Here's a link (think I found it here on the forum) that has everything you may need to make all your wiring modifications look original. http://www.repairconnector.com/
The connector you need for a 12 gauge connection to the under hood side of the fuse block is also available at this place. I got my HEI connector for the distributor and correct pink wire from a 70s GM truck. There are also pigtails on eBay with the correct distributor connector. |
07-04-2013, 01:00 AM | #16 | |
Re: HEI info needed
http://www.repairconnector.com/produ...d-Repair-.html So maybe the OP question about 18 ga wire would be ok? Posted via Mobile Device Posted via Mobile Device
07-05-2013, 12:46 AM | #17 | |
Re: HEI info needed
Here's a link to the split tab connectors in 10/12 ga. that I referenced in my post above to use as a replacement connector when replacing the resistor wire from the under hood fuse block . |
