Old 07-03-2013, 11:16 AM   #1
Thundarr
Thundarr's Avatar
Ride Height Recommendation/Pics
One of the PO cut my springs in front and removed the stops. They used air bags to lower in the back and one side seems to have a slight leak. I want more travel and dont necessarily want to ride that low. In consideration of cost, I'd like to replace all around with springs first without installing lowered spindles up front.
Question:
Can I get some of you to post pictures of your ride height with 20" wheels and just lowering springs (no lowered spindles)? Which springs did you use and what is your ride height?
Thanks!
This is where it sits right after I air up the leaking driver's side rear bag.
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 07-03-2013, 11:33 AM   #2
knomadd
knomadd's Avatar
Re: Ride Height Recommendation/Pics
I'm not sure how many you'll find without spindles. If you do an all spring drop, the ride is definitely rougher and you run the risk of bottoming out the suspension, depending on how low you want to go.
Here's a link to fleetsides with 20's of various drops. http://www.67-72chevytrucks.com/vboa...d.php?t=538914 I don't know if you'll find a spring-only drop in there though. This should give you an idea of how it will look anyway.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-03-2013, 12:09 PM   #3
Thundarr
Thundarr's Avatar
That's what I'm looking for. Thanks Duane.
Looks like I'll start with the spindles.
Old 07-03-2013, 12:21 PM   #4
knomadd
knomadd's Avatar
No problem. I could have sworn there was a thread for static drop pictures, but I can't seem to find it right now. IF I do, I'll post up the link for you.
-Duane
Old 07-03-2013, 12:25 PM   #5
knomadd
knomadd's Avatar
Ha! Found it...
http://www.67-72chevytrucks.com/vboa...d.php?t=471442
15 pages of pics and comments, but all sorts of variations on static drop of different years and wheel sizes.
-Duane
