Old 07-03-2013, 05:49 PM   #1
64tantruck
64tantruck's Avatar
61 master cylinder booster questions
All.
Was thinking of going to the local yard to get a booster and brackets etc.. I can get this from AutoZone for about $120.00
Can anyone tell me if they think this will bolt up to my firewall on the 61?
See the pic below. Bracket is included
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 07-03-2013, 06:49 PM   #2
slepysal
slepysal's Avatar
Re: 61 master cylinder booster questions
In a nut shell no. Is your 60 an automatic or a stick ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-03-2013, 07:10 PM   #3
64tantruck
64tantruck's Avatar
Its an automatic
Glenn Korec
Jamesville NY
Old 07-03-2013, 07:15 PM   #4
slepysal
slepysal's Avatar
Ok try this link
http://www.67-72chevytrucks.com/vboa...49#post3479149
The mounting holes on the 60-62 are difrent but this should do the trick for you.
Old 07-03-2013, 07:18 PM   #5
64tantruck
64tantruck's Avatar
Thanks for the link. Im not opposed to drilling some holes.
Glenn
Glenn Korec
Jamesville NY
Old 07-03-2013, 07:27 PM   #6
slepysal
slepysal's Avatar
are you going to swap out the drums?
Old 07-03-2013, 07:30 PM   #7
64tantruck
64tantruck's Avatar
already upgraded the front end from a 72 wd. Have 6 lug 1 1/4 rotors. New calipers, etc... Working on running new brake lines.
Glenn Korec
Jamesville NY
