07-03-2013, 08:58 PM | #1 |
where is 3 speed manual trans drain plug?
hi.
newbie here. trying to find the drain plug for a 3 speed manual trans. just bought a 1977 c10 250 engine 3 speed manual trans. I am changing out all of the fluids and belts and hoses. so far, so good. I am at the point where I want to change the manual trans fluid. I found the fill plug (man, is it on tight, but that is another story...), but I can't find the drain plug. I searched the net, this forum, the Haynes and Chilton books, and can't find a pic of the drain plug. I see other bolts that look like they hold the trans together, but no drain plug - at least no OBVIOUS drain plug. does anyone know where it is and/or have a pic to share? many thanks! |
07-03-2013, 09:31 PM | #2 |
Re: where is 3 speed manual trans drain plug?
There was two 3 speeds as I remember you could have a Saginaw or a Muncie 465. On the sm465 it's below the trans at the lowest point.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-03-2013, 09:59 PM | #3 |
Your saginaw never got one. You need to use a vac pump to extract it.
However I've used a turkey baster. Stop laughing! It works. Or a huge syringe works too! |
07-03-2013, 10:13 PM | #4 |
nothing wrong with the turkey baster! it works! ive one on old dirtbikes a lot haha
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
07-03-2013, 10:24 PM | #5 |
07-03-2013, 10:25 PM | #6 |
You can unbolt it and turn it sideways with the cover off. Get to inspect your gears and synchros that way. Just don't pull it out of the bell housing
07-03-2013, 10:28 PM | #7 | |
why do you think the Saginaw does not have a drain? (other than me not finding one... ) I am thinking there must be a way to service it. |
07-03-2013, 10:34 PM | #8 |
Your tranny has a seven bolt side cover. I had one in a 74. Even the muncie car 4 speeds didn't have a drain unless it was an M22.
07-03-2013, 11:02 PM | #9 |
optomistic ah-so
The servicing concept was, "Return to the dealership so we can sell you more maintenance and repairs, too."
Also, on economy trannies, engineers were under pressure from the infamous "bean-counters" that ruled the Corporations at the time. The fewer separate parts used in any assembly, the less the cost is to produce the assembly. Betcha someone at the topped, who raced using an M-22, had to send out a memo to get the plug back in that one...or fire someone. :-D
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
07-04-2013, 11:38 AM | #10 |
Watch out for your cornhole !
07-04-2013, 12:29 PM | #11 | |
07-04-2013, 12:47 PM | #12 |
I'm different on that. I'd take a 465 over two of the car 4 speeds. But, I need strength and don't care about weight or any form of speed of shifting.
Posted via Mobile Device |
07-04-2013, 01:42 PM | #13 | ||
but, if I wanted to give it a try, and leave the trans connected, is that seven bolt cover on the driver side? does it come down to: disconnecting any linkage, unbolt the seven bolts and remove the panel, drain out what I can (however I can) and clean it out, and put it all back together with a new gasket? Thanks |
07-04-2013, 02:27 PM | #14 |
Here you go. It won't get all of the fluid out, but it will get most of it.
http://67-72chevytrucks.com/vboard/s...d.php?t=348394 Posted via Mobile Device |
07-04-2013, 05:58 PM | #15 | |
maybe I will get lucky. I will give that a try and report back. |
07-04-2013, 07:38 PM | #16 | |
07-04-2013, 07:55 PM | #17 |
I hear you on upgrading the small 4 speeds. I kind of take the attitude to always try to use a heavier duty unit rather than attempt to fortify something lighter.
It's like the old saying. "Why build a 300 horsepower Honda when you can buy a 300 horsepower V8 cheaper and easier". The V8 will be less hassle and easier. It just won't have the novelty of a high strung little engine. I once built a 150 horsepower VW stroked engine with every good part money could buy. It wound up being about as fast as my wife's stock 5.0L Mustang and it was a temperamental little ***** to live with where the Mustang went 200k miles with only oil changes. Posted via Mobile Device |
07-14-2013, 10:53 AM | #18 | |
Saginaw 3 speed manual transmission DRAIN PLUG FOUND! it was as quoted in the above post - the bottom bolt at the rear of the main trans housing - the same housing that the fill hole is part of. it looks like just another bolt. i loosened it - it had a washer on it. I carefully took out the bolt and washer and out flowed the fluid! quite frankly, it does not look like a drain plug, it looked like just another bolt. very unusual design. Thanks to all for the replies! |
07-15-2013, 06:53 PM | #19 |
optomistic ah-so
Wow, I'm glad that came up on a thread I got subscribed to. I wouldn't have pulled that bolt unless I was swapping a tailshaft.
It still saves on parts, so I'll have to remember that when looking for drain plugs on other transmissions too. I wonder if magnetic drain plugs are available in that size, or if I'd have to make one. Hmm...
