07-04-2013, 11:04 AM | #1 |
Need some help. SERIOUS lean after DJM install
All,
I finished up my DJM 5/5 drop lon my 69 short bed ate last night. I did take before measurements and everything was spot on. 32" front and 34" rear. Now that the drop is on I sit WAY lower on the drivers side. I have seen people saying that 3/4-1" is normal. My problem is I am more like 2.5" lower on the driver. 28.5" driver measurement but 31" passenger. What is wrong? |
07-04-2013, 11:13 AM | #2 |
Re: Need some help. SERIOUS lean after DJM install
different springs? different spindles? you don't have the spring in the upper spring hat correctly?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-04-2013, 11:56 AM | #3 |
Springs and spindles are the same. I checked that. Good point on the spring hat. I will check that.
07-04-2013, 11:58 AM | #4 |
if you jacked on the body while doing the loweringjob your body mounts could b gone
07-04-2013, 12:05 PM | #5 | |
67-72 parts collector,…
1) lowered 5/5 2) front was 32", rear was 34" 3) how did you end up at 31" on the passenger side after a spindle spring drop? 1" total drop?
07-04-2013, 12:26 PM | #6 |
Unfortunately Keith you are tracking with me. I just went out and measured again. Still just 30" so a total of 2" on that corner. I just do not get it.
07-04-2013, 12:27 PM | #7 |
I used the DJM lower drop arms 3" and 2" springs. No spindles for those curious.
07-05-2013, 08:59 AM | #8 |
Update: It looks like the passenger front spring is hung up on the upper spring hat. I am taking it apart tomorrow.
07-05-2013, 09:14 AM | #9 |
Make sure the springs are seated correctly top and bottom. It can make a big difference.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
07-05-2013, 09:21 AM | #10 |
