Old 07-04-2013, 03:09 PM   #1
Mike Bradbury
Mike Bradbury's Avatar
Oil choking my carb
Since the recent rebuild of my 350, I have noticed that my carb has been coughing but only when it is cold. I thought it was just an issue with cold weather and it needed to warm up, but then when it was warm and it was still doing it I thought it might be something else.
This is only a weekend truck so after a year I only have 2500 miles on the rebuild.
One day I noticed that there was oil in my air cleaner! weird since my PCV sucks in the bottom of the carb any oil should be burned off or sucked into the combustion chamber.
I believe that the baffle plates that were welded onto the after market valve covers are too small to let only crank case gases by and it is actually letting oil by too. So I made a little device that will effectively separate the oil from the gasses. To test this theory I pulled the line into the carb, so now it was a passive system rather than an active system being drawn through by the carb. sure enough there was oil being sprayed on my valve covers through my after market vents.
Here is the device I made. It made it's first appearance at the Brother's Truck show this weekend, and I got many questions like; "what is that thing?"
In 250 miles of driving I got about a teaspoon of oily gas blow by residue. I have some questions for the guys at Crower and my engine builder as to why there is so much but here is some pics I snapped of it.
This is what is inside the can
There is a drain on the bottom
A screen filter on top
The top clamp
The carb plate
Here is what I caught after 250 miles
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 07-04-2013, 10:11 PM   #2
ole dollor
ole dollor's Avatar
Re: Oil choking my carb
first question i have is your motor using any oil ? and are you sure your pcv system is working prop.
ole dollor is offline   Reply With Quote
Old 07-04-2013, 10:33 PM   #3
Rufton
PCV valve cover baffles must not be working very well; I've had similar issue.
Twould be nice if oil separator drained oil back into valve cover; maybe version 2.0
Well, it works and looks kinda cool
Rufton is offline   Reply With Quote
Old 07-05-2013, 02:04 AM   #4
Mike Bradbury
On the original stock valve covers, the plate has a whole baffling system before it even gets to the PCV. These aftermarket V.C.s only have a small plate of aluminum welded under the breather hole. It is a newer Eldelbrock carb with plenty of suction, and I installed a brand new PCV at the time of the rebuild. I do have some questions for the builder and Crower because I think something might be shredding inside the engine. If you look at the pic of the oil in the bottom of the container you can see little bits of shiny pieces. they are not magnetic so I think it is just in the beginning stages of wear but still way too premature.
Old 07-05-2013, 02:39 AM   #5
Rufton
I like to cut every filter and inspect element.
Good way to see if glitter getting progressively better or worse.
Old 07-05-2013, 09:31 AM   #6
Lee H
Lee H's Avatar
High mike, I saw the separator at brothers and suspected you were having a blow by issue but did not get a chance to talk to you. I also did not know you had a fresh rebuild, given that its time to have a sample of your oil analyzed to find out what is breaking down. Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-05-2013, 09:59 PM   #7
Mike Bradbury
Yeah that is why I saved it in the container. When I first opened the separator it smelled much more like crank case gases but after a couple of days it smells more like oil. It always looked like oil but the gases have evaporated and left just the oil.
Old 07-06-2013, 11:24 AM   #8
Lee H
Lee H's Avatar
You, Crower, and your engine builder will want to know what's in the oil and will provide relevant data. I would get two samples analyzed, one with the oil in the separator you have now and one with a fresh oil change and 500-1000 miles.
Old 07-06-2013, 12:43 PM   #9
Mike Bradbury
Who analyzes oil?
Old 07-06-2013, 01:10 PM   #10
Lee H
Lee H's Avatar
There's a bunch of them, just Goggle. Check out the process and a few sample reports to see if they will work for you. I used one about 10 years ago to prove to a builder that there was to much metallic floating in the oil after he looked at it and said that was normal for a fresh engine with only a few thousand miles. Turned out he did not machine the front of the block enough so the double roller chain finished the job. Good cleaning, new bearings, rings, and I was good to go. Engine now has 70K and no issues, does not burn any oil and gets used hard.
Old 07-06-2013, 08:15 PM   #11
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
I'm not a mechanic so I may be wrong, but I've never owned a car where the pcv line went to the vacuum on a carb. They have always went to the air cleaner, I don't think they need that much flow. I also think it would kill your vacuum. All my vacuum lines are closed, meaning there is no lose of vacuum.
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 07-07-2013, 12:52 PM   #12
ole dollor
ole dollor's Avatar
it should go to vacuum , thats how it works. double check yours ..breather tube hose goes to air cleaner...
Old 07-07-2013, 01:15 PM   #13
Don Quixote
Don Quixote's Avatar
I am wondering if I am not having a similar problem. My valve covers are flipped I guess to make adding oil a little easier but the idea may be backfired by the fact that there is where all the oil pressure is.
A theory unto this, could I add an inline fuel filter to absorb the oil before going to the carb? I have an open element ait cleaner and my carb has the PCV port on the bottom?
As it is, I am puffing a little smoke at high vacuum and I had thought it might be a ring or a valve seat but this thread got me thinking...
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 07-07-2013, 01:24 PM   #14
Lee H
Lee H's Avatar
If you getting oil going through the PCV system to the carb you either don't have good, or any baffles in the valve covers or your engine is producing way to much blow by, indicating an over haul is needed. After market valve covers are notorious for allowing oil to be sucked into the PCV hose.
