Old 06-30-2003, 09:50 AM   #1
71blazerman
Blazer Hardtop brackets
I desperately need the brackets that hold the blazer top to the windshield frame. I found a local guy with a double wall, still looking for a single wall. thanks
Scott
67 Impala SS Conv
66 Caprice 396
No more trucks.... someday though
71blazerman is offline   Reply With Quote
Old 06-30-2003, 12:14 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
which brackets? The ones that have the sunvisors, the other two, all four?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-30-2003, 12:20 PM   #3
71blazerman
I didn't realize there were different types of these, whatever you have, I just need to keep the hardtop on.
67 Impala SS Conv
66 Caprice 396
Old 06-30-2003, 12:50 PM   #4
Crew Dawg
Check out coloradok5. They may have something for you.
69 Chevy swb
72 blazer 4wd
Crew Dawg is offline   Reply With Quote
Old 06-30-2003, 01:32 PM   #5
TrucknVA
I have set of brackets from a 72 DOUBLE WALL TOP? Do you have a pic somewhere of what your looking for?
I have a few other blazer parts laying around also?
TrucknVA is offline   Reply With Quote
Old 06-30-2003, 02:01 PM   #6
71blazerman
I don't have any pics of these, can someone take a pic of theirs?
TrucknVA, I sent you a PM.
Thanks,
Scott
67 Impala SS Conv
66 Caprice 396
Old 06-30-2003, 02:56 PM   #7
mkmiller1
mkmiller1's Avatar
Here is a pic of the brackets(need two) that go in the center. If you have sunvisor brackets, you've got the outer ones. In the sunvisor brackets there is a hole to put a bolt thru to screw into the top at the corners. If you don't hook up with some one else I've got what you need.
Thanks,
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 06-30-2003, 03:30 PM   #8
71blazerman
Were the bolt pattens on windshield frame and top the same regardless of which brackets you have? I have a separate pattern on my windshield frame for the sunvisors like the pic shown, so are there two types of windshield frames and two types of bolt patterns for single and double wall tops? Was one pattern for the single wall and one for the double? Thanks for the clarrification guys, I thought I knew all about these trucks, fun learning again.
Scott
67 Impala SS Conv
66 Caprice 396
Old 06-30-2003, 11:14 PM   #9
mkmiller1
mkmiller1's Avatar
Scott-To the best of my knowledge both tops buckle down the same on the windshield frame, they only bolt different on the bedsides.
Matthew
