07-05-2013, 07:51 AM | #1 |
need to find 235 part
first time posting,did intro on 1970 chevy LB.i started to dabble with a 1958 chevy 235 engine.i discovered during disassembly i need a nut for a connecting rod.tryied numerous searches on the net,ebay and junk yard in my area for a 235 dead engine,just for a nut with no luck.is there a parts store or dealer that i missed that i could buy the part. any info would be helpful.
07-05-2013, 10:24 AM | #2 |
Elev8r Man
Re: need to find 235 part
Is a 216 nut the same? I am going to go out on a limb a take a wild guess but I wanna say that 216 - 250 should be the same, am I wrong? If so, someone please correct me.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
07-05-2013, 10:38 AM | #3 |
I did not do any search but you might check ARP and look over at inliners.org, they would know a source.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-05-2013, 02:34 PM | #4 |
The rod nut isn't that application specific. If I remember correctly, it's a 3/8 x 24 nut which is the same as all later 350, etc. V-8's. In that low performance app, even a used one from an automotive machine shop would work just fine but any good auto parts store that carries Dorman stuff will have a new rod nut. If it happens to be 11/32, which is an oddball, it would be the same as the earlier 265, 283 V-8s. If it happened to be 5/16, that's the same as 289/302 small block Fords. Any of these, even used shouldn't be a problem and if it used a pal nut/lock nut, it's just fine to leave it off. I never use them on old builds I do, jut upgrade the nuts to Pioneer, ARP or whatever and torque them properly. That's 1940's thinking.
07-05-2013, 05:00 PM | #5 |
it looks like a 9/16 24 nut,will try local napa for a nut thanks a bunch guys
07-06-2013, 11:27 AM | #6 |
ues guys are Great.went dorman online catalog found conneting rod nut.stop in at at my local auto parts store and ask for a dorman 635-002 from a 1992 c1500 with 454 they had it for whopping .54 cents with mo.tax.thans again for the ideas.
07-06-2013, 12:21 PM | #7 |
Hollister Road Co.
Its always good to find your nuts locally when you need them.
07-06-2013, 01:12 PM | #8 |
07-06-2013, 05:01 PM | #9 |
The problem is the older you get the more often you misplace your nuts.
07-21-2013, 01:47 PM | #10 |
test i guess
07-21-2013, 06:48 PM | #11 |
I always check my wifes purse first...
07-21-2013, 10:32 PM | #12 |
If I leave mine laying around my wife puts them somewhere and promptly forgets what she did with them. Seems I am constantly looking for my nuts.
07-21-2013, 11:21 PM | #13 |
Hollister Road Co.
I suppose thats better than the squirrels burying them in the yard somewhere or worse the neighbors yard.
07-22-2013, 09:55 AM | #14 |
Actually, Dave it's about the same.
07-22-2013, 10:14 AM | #15 |
you guys are most funnneeeeee
