07-05-2013, 10:01 AM | #1 |
2WD Jimmy
Blazer door reassembly order
Is this the correct door reassembly order?
1.install regulator 2.install door glass 3.install vent window 4.install rear door glass guide 5.slide in rear door glass glide felt (I know there is a small screw in the top, but do you need to use any 3m rubber adhesive to keep it in the channel?) 6.install door glass squeegees |
07-05-2013, 03:47 PM | #2 |
Re: Blazer door reassembly order
Add some time for cursing in between each of those.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
07-05-2013, 05:15 PM | #3 |
Not sure of this Tom, but you may want to assemble the reg. and window without mounting the bolts for the reg. up. Try it outside the door first, and see how it goes together. For some reason it sticks in my head that thats the way i did it. Somehow i supported the weight of the glass, half way in the door, then offered up the reg. to the bottom of the window glass channel
Just dont put your vent window in first, or you will be taking it out like i did to put the window in I built some j hooks for the wipers out of sheet metal, easy to pull up the clips for the wipers Let us know how you made out, and what not to do
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-05-2013 at 05:22 PM. |
07-05-2013, 08:18 PM | #4 |
go cyclones
X2 on the cursing
Posted via Mobile Device |
07-16-2013, 01:02 AM | #5 |
Recalculating.....
I just did a disasembly and wrote it down. Ill get back to you on it.
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
07-16-2013, 09:32 AM | #6 |
2WD Jimmy
I actually got it all back in without to much cursing, lol.
07-16-2013, 03:59 PM | #7 |
BBrendal could you send me your notes? I'll be doing the same thing soon and would also like to avoid the cursing in between steps as much as possible!
07-17-2013, 09:39 AM | #8 |
2WD Jimmy
07-17-2013, 04:22 PM | #9 |
excellent post. thanks for sending it
07-18-2013, 11:10 AM | #10 |
That's awesome, much appreciated!
07-18-2013, 05:06 PM | #11 |
Recalculating.....
Acording to my notes Tom has the same procedure I do. Plus the links are a great help.
