Old 07-05-2013, 01:56 PM   #1
Acksman
Steering Column bracket parts missing - diagram?
Small back story, I removed my steering column about 20 years ago and I am missing some parts. I bought an aftermarket tilt column to go in, but have no clue where to bolt it to under the column.
I have done some Google search on diagrams but not having much luck. Could anyone point me to some images of what all the parts look like under the dash that connect the steering column in place?
Hopefully I can buy the parts aftermarket or its off parts searching. Here is what I have right now and I seem to only have the one bracket. A picture of what I am trying to put in and all its pieces.
Thanks all!
Yup not good
Side angle
Only bracket I have
What I'm trying to put in, hopefully I have everything past the brackets to make this work.
Acksman is offline   Reply With Quote
Old 07-05-2013, 02:44 PM   #2
doobiebro
doobiebro's Avatar
Re: Steering Column bracket parts missing - diagram?
What year is your truck? 60-62 I believe have a round clamp mount bracket inside your lower fire wall before it exits the round hole. 63-66 has the round clamp bracket outside the fire wall in the engine compartment under master cylinder... I installed a GM universal tilt column similar to yours and was able to use the original lower steering column bracket you show in your picture. You will need it if you are still gonna use your park brake lever
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 07-05-2013, 02:45 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Not sure how much these will help, but they’re all I could find in the 1960 Chevy Truck Shop Manual:
And here's an old thread that may show something worthwhile:
http://67-72chevytrucks.com/vboard/s...ffler+clamp%22
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-05-2013, 03:21 PM   #4
doobiebro
doobiebro's Avatar
Acksman found some pics... top pic 60-62 lower pic 63-66
Old 07-05-2013, 04:16 PM   #5
Acksman
Thanks all that helps a lot. I have a 66.
On a whim found a salvage yard guy has a 66 with air / tach and two ash trays with the cig lighter for the passenger side as well. Has just about everything I would need but he's asking 3k. Never seen one with this many options that I'm missing. 3k sounds a bit high though.
