07-05-2013, 04:41 PM | #1 |
Bed wheel tubs stepside
So im debating to do it or not. From what I measured I would gain about 3 inches of tire space on each side.. What did you guys use for fender wells?
Pictures would be awesome. Or even a tire size without the tubs in place. Seen some post where guys were running wide tires but I had 235s with an axle flip and they didnt have much room. |
07-05-2013, 09:26 PM | #2 |
Re: Bed wheel tubs stepside
Do a search. There was a recent thread with lots of ideas and pics.
07-05-2013, 10:25 PM | #3 |
Some of the guys have cut down the inside fenderwells for the fleetside pickups up through 87 that bolt into the pickups. It gives a clean look and the flange on the inner well bolts to the bed floor and looks like it was intended to be there. You have to be able to do some serious welding to narrow the inner wells though.
07-05-2013, 10:41 PM | #4 |
Certified Car Nut
I used trailer fenders to make my tubs.
07-06-2013, 10:38 AM | #5 |
I'm running 275 60 15's on a Chevelle rear end so I had to make more room on the inner fenders. I took the advice of guys here that had done this mod and used 16 ga sheet metal and the original piece I cut out
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
07-06-2013, 01:13 PM | #6 |
Dang never thought about that. And it looks pretty original the way the lines follow it. Dang thats alot of welding haha.
07-06-2013, 04:14 PM | #7 |
They still need to be ground down, but it took about 3 hours to fab it all up. I didn't want to warp anything
07-06-2013, 11:23 PM | #8 |
This is a motorcycle rear fender half
07-06-2013, 11:48 PM | #9 |
I am thinking of cutting down a 55 gallon metal drum on my fleetside bed. I can get the drum for $15....
07-07-2013, 09:26 AM | #10 |
Classic truck magazine has a article on them. Sept issue.
07-07-2013, 12:40 PM | #11 |
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-07-2013, 01:45 PM | #12 |
Those trailer fenders like Kabwe showed are usually under 20 each and can be found in bare steel at places like Tractor Supply. They also allow you to build something that has a very clean appearance rather than something that looks rat rod scabbed together.
I like that really smooth setup that Papastrk showed too along with Orge's usually high quality work. A guy might also look at the spare tire covers off the 80's/ 90's conversion vans that had a nice curved metal face that would work well with a strip of metal the right width welded to it. The band on those is usually chrome or stainless though.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 07-07-2013 at 01:50 PM. |
07-10-2013, 09:25 PM | #13 |
I like the way it looks with the section back in. And 10 gauge is pretty thick stuff
Posted via Mobile Device |
