Old 07-05-2013, 04:57 PM   #1
Turkey
Turkey's Avatar
shocks and bags or just bags?????
I have never had a vehicle with air bags, but have convinced myself that's what I want to put on my 65. Are shocks mandatory with bags? Why do some people use them and some people don't? I notice that trailers only have bags (18 wheelers). So what's the deal with shocks and bags or just bags? Thanks in advance for your experience and advice.
Turkey is offline   Reply With Quote
Old 07-05-2013, 05:19 PM   #2
knomadd
knomadd's Avatar
Re: shocks and bags or just bags?????
Some are built as both, like Ridetech's Shockwaves. They are both air spring and shock in one. From the research I've done, you need shocks too, otherwise it's like riding on just coil springs. But, I'm new to air suspension so that's just from my little bit of research.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-05-2013, 05:42 PM   #3
vegadesign
vegadesign's Avatar
highly recommend shocks. granted you can drive without them but you will notice a smoother ride with shocks
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 07-05-2013, 07:35 PM   #4
hellbent72
You will want shocks for sure. It will ride much smoother.
hellbent72 is offline   Reply With Quote
Old 07-05-2013, 08:39 PM   #5
broey
Square
broey's Avatar
you can run slam bags without shocks. but for a smoother ride just put shocks on. they are pretty much the easiest part about bagging a truck.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 07-05-2013, 11:02 PM   #6
cubber
Definitely use some type of shock. It is too simple to skip.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 07-07-2013, 09:33 AM   #7
northeimcustom
northeimcustom's Avatar
shocks are the ticket! unless you like to bounce around a lot......
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 07-07-2013, 11:55 AM   #8
SCOTI
SCOTI's Avatar
Air bags are air 'springs'. A springs job is to support the weight of the vehicle. As the vehicle travels down the road, it travels through it's compression/extension range. The shocks job is to dampen the movement as it moves through the range.
No shocks mean nothing controlling the springs inherent bounce.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-07-2013, 02:32 PM   #9
vegadesign
vegadesign's Avatar
I drive without shocks in the front due to the weight difference
The rear will bounce around a lot more without shocks
Old 07-07-2013, 03:31 PM   #10
king-918
king-918's Avatar
18 wheelchairs are setup different than trucks, it easier to put shocks on the cab or seats then put shocks on a million pounds of metal. But in my opinion shocks is a must for creature comfort.
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 07-08-2013, 01:28 PM   #11
ob1monkey
I have always had shocks on mine, can't imagine it without them. I am sure if you run enough pressure it would be fine, althought it may feel like you have no springs . I am local and am willing to offer any advise you need, my truck is currently under construction with the bed off. your welcome to come by and see whats going on. my new accuair valve shows up tomorrow.
If you want advise on what to order I would say 2600lb bags on all four corners, a good valve, plates and cups up front, depending on the your ride height you want, drop spindles. shock relocation kit out back and an adjustable panhard bar.
I'm pretty sure I've pm'd my number before feel free to contact me anytime.
Ben
ob1monkey is offline   Reply With Quote
Old 07-08-2013, 02:24 PM   #12
19666Trucker
19666Trucker's Avatar
all of the air ride semitrailers in my company fleet have shocks, it limits the travel, cushion from bouncing down the road. i would go with shocks, it give better control when brake and corner,
19666Trucker is offline   Reply With Quote
Old 07-08-2013, 03:55 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Here is the correct answer. If your bagged with no shocks then your not finished with your system. Do it right, or dont do it at all.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
