Rear leaf spring lateral play - bushings?
When I replaced my front axle for a drop axle, I noticed that there was excessive side to side play in my front leaf springs. It seems that the spring eye bushings were pretty worn. I replaced the front springs (since I had another set) at that time and noticed that the play was greatly reduced.
I checked the rears and found even more play than the front. I'm assuming that these are the original springs with the original (or at least super-old) bushings that need to be replaced. I also notice a significant left/right movement when going over a large bump such as a bridge approach. I do not feel the movement over a straight bump (90 degree approach), only when there is some angle to it (either a slight grade to the road or an angled approach). I don't have an issue when hitting a regular bump in the road as I would attribute to bump-steer, or at least my understanding of it. Can the original spring eye bushings (rubber and all) be replaced? I really don't want to buy new springs unless I have to. Are there any options for poly bushings or is that only for newer trucks? Any advice or shared experience would be greatly appreciated. Thanks, JJ |
Re: Rear leaf spring lateral play - bushings?
as long as your spring eyes are in good shape, all the pins, bushings and shackles are replaceable
you don't say what yr truck you have, go to LMCtruck.com suspension parts start on page 89 and yes, these worn parts can create havoc on your steering
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#3 | |
Ooops, forgot to mention it's a '59 3100. I assume that this is just pressed in/out? Last edited by agnes the dog; 07-06-2013 at 10:50 AM. Reason: added info |
yes. put your truck year and model in your signature and you will never forget it again
![]() no rubber, it's all steel and brass. keep it well lubricated. if the bushings and pins have play, replace them all. lots of little things with play add up to a lot of slop in the steering and back end
Thanks Ogre.
Posted via Mobile Device |
