Old 07-06-2013, 10:59 AM   #1
White70C20
White70C20's Avatar
Recommended performance upgrades?
Before I go to college this fall, I would really like to make my truck run better. Here's some quick info on my truck as it sits:
Engine: 350, Carter AFB 4bbl, Edelbrock intake, headers w/dual straight pipes.
Transmission: stock TH350.
4:10 rearend.
Does anyone have any ideas for some fairly cheap performance upgrades?
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 07-06-2013, 11:14 AM   #2
Lee H
Lee H's Avatar
Re: Recommended performance upgrades?
If you have not done it yet, the biggest performance bang for your buck is a real tune-up. Get the distributor tuned, fresh parts, and dialed in for proper mechanical & vacuum advance, fresh wires and plugs. Next check plugs for clues to carb function, not to lean, not to rich. If this is already done, what is your budget for mods?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-06-2013, 11:31 AM   #3
FLDBRED
If you want to save yourself a lot of headaches, change from the points to an HEI,you won't regret it!
FLDBRED is offline   Reply With Quote
Old 07-06-2013, 11:36 AM   #4
White70C20
White70C20's Avatar
I guess I should've asked this question first: Is a 2 wheel drive 3/4 ton pickup worth modifying? It's not fast by any means.
It already came with HEI when I bought it.
White70C20
2005 Pontiac G6
Old 07-06-2013, 11:51 AM   #5
Lee H
Lee H's Avatar
[QUOTE=White70C20;6159392] Is a 2 wheel drive 3/4 ton pickup worth modifying? QUOTE]
Of course it is, Start with all the safety stuff first, brakes, suspension, steering, then mod away with performance goodies.
Old 07-06-2013, 11:56 AM   #6
69 MOD
69 MOD's Avatar
So cover the basics like they said,
tune up: cap, rotor, plugs, wires, fuel filter & Check Your Timing (often overlooked and believe it or not it isn't always on) this only takes a minute
As mentioned by Lee H read your plugs - http://www.4secondsflat.com/Spark_plug_reading.html
Then you can make carb adjustments to help efficiency (efficiency = performance too)
The basics can go a long way...
MOD
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
Old 07-06-2013, 12:57 PM   #7
White70C20
White70C20's Avatar
Ok. Thanks!
White70C20
2005 Pontiac G6
Old 07-07-2013, 12:35 AM   #8
Crewchief22
Crewchief22's Avatar
Do a compression test and a leak down test (if you have access to a leak down tester) to see if all cylinders are similar. Might not be a bad idea to go through and check the valve adjustment while you're under the hood.
Crewchief22 is offline   Reply With Quote
