Old 07-06-2013, 11:16 AM   #1
60-66
60-66's Avatar
17.5 Tire suggestions
Does anyone have any tire suggestions for a stock 17.5 rim ? I'm putting them on my 63 GMC 4X4 half ton. Would like a little more aggressive look than just a stock radial tire.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 07-06-2013, 02:31 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 17.5 Tire suggestions
I looked for 17.5 and 19.5 just to prepare for the 4x4 I might get and came up empty. Although I was at Discount Tire and some one ordered a set of 285/65/16 BFG Mud terrains for a truck and they look good like a new version of bias ply tread. Tall and narrow like these trucks came with. You might want to look for a more available rim size.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-06-2013, 07:23 PM   #3
factorystock
factorystock's Avatar
The period 8-17.5 tire is available with traction tread, but it is a bias ply tire not radial.http://www.stausaonline.com/light-tr...r-traxion.html
factorystock is offline   Reply With Quote
Old 07-06-2013, 07:53 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Coker tire!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-07-2013, 01:58 AM   #5
stormking
When you get them found and mounted please show a picture. I hope to be shopping for the same tires very soon.
stormking is offline   Reply With Quote
Old 07-07-2013, 08:50 AM   #6
60-66
60-66's Avatar
http://www.tirerack.com/tires/tires....07250000390781
http://www.ebay.com/itm/LT235-75R17-...d2e180&vxp=mtr
http://www.ebay.com/itm/Road-Lux-215...dd4f37&vxp=mtr
Old 07-07-2013, 11:33 AM   #7
factorystock
Originally Posted by Clyde65 View Post
Coker tire!
http://www.ebay.com/itm/Coker-Vintag...77d61f&vxp=mtr
Old 07-07-2013, 12:06 PM   #8
oem4me
Originally Posted by factorystock View Post
That tire looks great with the pie crusty edge. The listed diameter seems off at only 26.6 " ?? I would have guessed much taller.
Old 07-07-2013, 12:11 PM   #9
soxplayer
I gave up on 17.5 due to the price. I went out and got a set of 16 inch 8 lug steel rims and mounted a set of 235/80/16 Kumho tires. Good performance and not exactly a stock look. Here is the link where you can see a picture.
https://www.tirerack.com/tires/tires...omCompare1=yes
There diameter is listed as 31.7 but I think they are slightly shorter. They are still taller than the old 17.5 spare I have lying around and taller than the Yokohama Super Steels with a lot lower price. If you are like me, a "goodyear overdrive" is an important part of the tire selection process.
soxplayer is offline   Reply With Quote
Old 07-07-2013, 12:21 PM   #10
60-66
60-66's Avatar
Do you think that would look right on a 1/2 ton 4x4 though ?
Im leaning towards these,http://www.tirerack.com/tires/tires....07250000390781 one because its a LT radial .But the price with shipping is around 1600.00 . I bought a set of these in 15s, much cheaper, and they look great on my 63 half ton 2x4 longbed.
Old 07-07-2013, 12:31 PM   #11
oem4me
Oh, no, I guess you'd need a bit more tread on a 4x4. I still love the edge though.
Old 07-07-2013, 06:35 PM   #12
factorystock
This must be an error by the seller ( summit), no way is it 26.6". STA lists the same tire at 31.4" http://www.stausaonline.com/light-tr...transport.html
Old 07-07-2013, 07:42 PM   #13
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
That's a big tire. I run those on my Winnebago.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-07-2013, 07:55 PM   #14
285/65 and not 285/75? re you sure you don't mean 285/75? They're about 32" tall and about 9" wide. 65 series would look more squatty. 85 series are about what profile the old bias plies tall skinnies were. A 235/85-16 is close to the 7.50-16s and the 255/85s are close to the 9.00-16s. Those sizes would look great on that K10
Old 07-14-2013, 10:05 AM   #15
factorystock
Universal tire has the17.5" bias ply in hwy and traction.https://www.universaltire.com/truck-...truck.html?p=2
