Power window regulator removal tip
Here is what I have found to be the best regulator position for removal from the door through the 8"x8" hole in the upper left opening in the door. I removed the regulator/motor assembly via motor and gear section first (turning the assembly upside down prior to removal.)
It took about an hour of experimentation before I figured this out. I have done this task several times before but forgot how to do it. I am sure there are other methods, but this one worked best for me. |
Re: Power window regulator removal tip
Thanks for the info, I left mine in and replaced the motor. What a pain
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
| Bookmarks |
