Old 07-06-2013, 05:56 PM   #1
Gorn
Gorn's Avatar
Sitting for 35 years
Looks like I am buying a 72 shorty that has been sitting for 35 years. I think I have a good Idea on what needs to be done. I would like to start a discussion maybe someone who has done this already will have some pointers.
The truck is a 72 with 35K on the clock. It is a I6 3 on the tree.
Check to see if the motor is frozen
Check to see if the clutch is rusted
Change oil
Drain and flush coolant
Service rear
Service manual (Do they have drain lugs?)
Crain brake fluid
Disassemble brakes all around, Rebuild calipers and wheel cylinder Replace master cylinder. Replace flex hoses, inspect metal lines, one heck of a stomp test once it done.
Drain fuel tank, Replace rubber fuel lines. Filter
I am sure I am missing some stuff.
It is better to live one day as a Lion then 100 years as a Sheep
Dingers Build Thread
Dingers Before Pic's
My 67 Camaro
Gorn is offline   Reply With Quote
Old 07-06-2013, 06:03 PM   #2
Saclandman
Saclandman's Avatar
Re: Sitting for 35 years
I just did this. Found a 67 that had been parked in a field for 30 plus years. After replacing all ignition parts, fuel sending unit, and filters, she fired up. Needs a lot more work before it'll be road worthy, but a great start. I hope you keep posting your progress. Good luck.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 07-06-2013, 06:12 PM   #3
Chrome8
Chrome8's Avatar
Congrats on getting that time capsule bought! Did he take your offer? I'd be interested in seeing some pics of that truck in the raw before you get it cleaned up. Great job.
Chrome8 is offline   Reply With Quote
Old 07-06-2013, 06:40 PM   #4
Gorn
Gorn's Avatar
Ya, He called me tonight. He is such a nice guy. He found most of the original paper work that came with the truck. He even said he had two new tires. We talked for a while he agreed next weekend we are going to see if the motor is frozen and check the clutch and if I can just pull it home on a tow rope or if I will need a flatbed. I am not too worried either way. It only needs to go 800 ft
Hopefully I will get some pics next weekend.
My 67 Camaro
Old 07-06-2013, 06:53 PM   #5
hugger6933
Belts/hoses vaccum lines, fuel lines. also need to be on the shopping list. Pull the valve cover and check for build up of who knows what I have and have also seen done filling the motor up with diesel or kerosene[lot more costly] and letting sit for a day or so and that will loosen the inside varnish buildup and then pull the drain plug and it will come out with the diesel, but you can tell more about needing that or not by pulling the cover. A carb kit is gonna need to be ordered as well, so start digging around on it for the proper numbers there. Ignition will need to be addressed I would think about an hei and that would get the wires and most of the rest of the tune up stuff done. Good luck on bringing her back from the brink of a rusty demise. Jim
hugger6933 is offline   Reply With Quote
Old 07-06-2013, 07:51 PM   #6
69chevy lwb
69chevy lwb's Avatar
Don't start buying all this stuff check to see if the motor has oil in it if its over full it may have water in it you won't know until you get it churned up. then try turning it over by hand if it does pull the distributor and prime the oil system starting an engine dry will take out 80% of the bearings life past that see if it has fuel,spark,air,and compression if so it should run set timing you will need to clean the fuel system out too
69chevy lwb is offline   Reply With Quote
Old 07-06-2013, 08:14 PM   #7
roughedup72
roughedup72's Avatar
awesome. now all we need are pictures.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 07-06-2013, 08:34 PM   #8
68GMCburban
68GMCburban's Avatar
Sounds cool!
-Holden
1983 & 1972 Chevy Longbeds
(16) 67-72s (Rollback, 402's, Sierra Grande, Shortbeds, Shortsteps, Longhorn, etc)
1968 GMC Suburban- (Current project) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=569806
(6) 60-66s (shortstep, rollback, two-ton, longbeds)
(3) 47-59s half tons
+ MANY more and always looking for more
68GMCburban is offline   Reply With Quote
