4x4 conversion pics
I would like to see some pics of 2 wheel drive to 4 wheel drive. Looking for pics of actual conversions not just body swaps. I specifically want shots of the transfer case and in the cab where the shifters come through the floor. Thanks.
67 C10 swb bored out 350 granny 4 speed I come from a long line of moonshiners |
Re: 4x4 conversion pics
![]() ![]() Join Date: Feb 2004
I used a NP 208 behind a 350 turbo. The shifter is from a Chevy 1990 ton NP 241. It was on driver side of hump. I turned it around and put it on the passenger side. I fabricate what ever I need. Lever position is in 2wd. Pulling it back takes to 4H, neutral and 4L. The Ford shifter has the correct pattern on it.
another picof use of switch on np 208. Green light comes on when in an 4wd.
Here's my conversion, everything is original to the frame. If you doing an all original swap like I did, there not much stuff to worry about. There's stuff that you have to change like, shift linkage (possibly, I had to on my). Have to change the transmission tunnel unless you already have a manual. Cab mounts and dont buy the cheap ones from oreillys go to lmc and get there kit. I also had to change my radiator hose on the bottom. You will have to watch you distributor to cab clearence. axle with disc brake conversion is one of the best things you can do, it was the cheapest thing and easiest to install.
I like it MO, I picked up a SS 454 14 bolt G80 3.73 for mine and converted it to 6 lug and added rear disc brakes. 5 to 6 was less complicated when I also used a 1.5 inch hub centric spacer.
Enjoying left field
The one in my sig is a 2wd to 4wd swap. Little different though.
my 87 shortbed build http://www.67-72chevytrucks.com/vboa...d.php?t=576936
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Nice! How do you like the dual shocks?
http://67-72chevytrucks.com/vboard/s...d.php?t=355153 |
59 frame and springs with 74 K10 drivetrain. 350/350TH/NP203 3.73 gears. 16" steel wheels. Lots of details in my build thread.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Sorry about that. I had some login trouble and then commented on the wrong thread.
Junior Member
Not sure what body style or years your wanting. Here's my 91' R30 converted to V30. Not finished yet but should be in couple weeks.
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
#13 |
Junior Member
Now
