RHCP afficianado
changing oil
Hey guys I decided to change my oil today but I cant get the drain plug off. Is it suppost to be that tight? How do you guys get it off? I'm putting a lot of force on it and it wont move at all.
~Ryan~ 89 S-10 Blazer with a 4.3L 96 Ford Crown Vic P71 4.6L V8. This car rocks. ![]() Here are some links to some good music. Jack Johnson Donavon Frankenreiter |
I had that happen once..... Sometimes they are just really tight! I also changed my oil today.
84 Chevy Stepside, 350, TH350, 268h Comp cam, Hooker headers, MSD Pro Billet, Edelbrock Performer manifold and 1604 carb, 40 Series Flowmasters dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi |
Whatever you do, do not strip the head of the bolt.
If the bolt starts spinning freely you might have a stripped bolt. If that is the case you can get it out with some plyers and a wrench. If only the bolt is stripped then you can replace the bolt itself. If the hole is stripped you can buy a replcement plug at checker. They stock them on the shelves next to the oil filter wrenches and funnels. It is a rubber type plug. When you tighten the bolt on this rubber plug it makes the rubber expand and seal the hole. Good Luck! When you put the drain plug back in snug it down and give it an 1/8 of a turn. You do not want to over tighten the drain plug. Some guys at oil and lube places tighten them way too much.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
RHCP afficianado
I got it off. It just took some really strong angry pulls.
I am always thinking the worse
![]() Glad to here everything is cool.
LED King
When that happens I give the wrench some "help" with a rubber mallet. Nice and softly at first, then I get mad & WHAM! Off it comes!
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
