![]() Join Date: Aug 2012
Port valve from master cly.
I have a OEM port valve. I had a after market port valve on my truck when I took it apart 11 months ago. With drums brakes all around. My question is: How do I figure the brake lines out?
I have front disk brakes and drums on the rear. 1/2 ton 2 wheel drive 1972 front sup. and 1972 rear end. so the brakes are 1972 set up. below is a picture of my master cly. and valve. both came off a 72 with disk on front and drums on rear.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper Last edited by gdavis; 07-09-2013 at 12:12 PM. |
member #16
![]() Join Date: Dec 1999
Re: Port valve from master cly.
1/2 ton 3/4 ton? year model?
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
And more importantly!
Discs/drums or just drums. And it's called a proportioning valve if you have disc/drums and a distribution block if you have drums all around. |
Here are the pictures of the master cly and port valve
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
Disc/drums or just drums?
front disk and drums on the rear
http://67-72chevytrucks.com/vboard/s....php?p=2659105
http://67-72chevytrucks.com/vboard/s...d.php?t=241722 SEarch with google images till you find what you want. There's more. Ask for 72 chevy truck m/c and prop valve |
