Old 07-07-2013, 04:10 AM   #1
mfm3
Active Member
will 15" stock wheels clear 2.5" drop spindles?
I searched for the answer to this question but was unable to find a definitive answer. I'm sure someone knows if I will have a problem or not.
mfm3 is offline   Reply With Quote
Old 07-07-2013, 04:55 AM   #2
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Re: will 15 " stock wheels clear 2.5" drop spindles?
In my case, 15 steel wheels hit the lower A arm with the 2.5"drop spindles
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 07-07-2013, 05:50 AM   #3
brokenspoke
brokenspoke's Avatar
I used 1970 truck wheels
brokenspoke is offline   Reply With Quote
Old 07-07-2013, 05:54 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
My 15x8" wheel rubbed so I put on 15x6.5 and they dont
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-07-2013, 07:00 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Stock what year wheels?
60-70 6-lug?
No.
There is usually not the correct clearance to clear the disc brake caliper that installs on your drop spindle.
Backspacing?
Yes the 15x6.5 steelies usually have the correct backspacing.
You need 71-87 4x4 steelies (6-lug).
Or run a 5-lug set-up with 71-87 2wd steel wheels.
Keith
Convert to disc brakes.
Old 07-07-2013, 10:23 AM   #6
mfm3
Active Member
60-70 6-lug?
No.
Backspacing?
The 15" wheels are six lug with 3.5" backspacing. I can go with a 2" drop spindle if I have to. What do you think?
Old 07-07-2013, 10:28 AM   #7
lolife99
lolife99's Avatar
As long as they are 71-87 4x4 steel wheels,... you will be fine.
Early pre-71 wheels won't work.
Keith
Old 07-07-2013, 03:58 PM   #8
mano
mano's Avatar
That looks like a pre 71 wheel.
mano is offline   Reply With Quote
Old 07-07-2013, 04:06 PM   #9
lolife99
lolife99's Avatar
Yes it is.
Keith
Old 07-10-2013, 11:46 PM   #10
Brad54
Brad54's Avatar
Not to hijack the thread, but there seems to be some good knowledge here--anyone know if vintage 5-slot, 6-lug wheels will clear 2.5-inch spindles and discs?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 07-11-2013, 08:27 AM   #11
Clyde65
Clyde65's Avatar
how wide, offset and pictures would help.
Clyde65
Rebuild of Clyde
support our troops!
