Old 07-07-2013, 11:22 AM   #1
heehawracing
heehawracing's Avatar
new 72 truck doorw
new never put on 72 truck doors bought from LMC 500.00
pick up only
770 468 7776
heehawracing is offline   Reply With Quote
Old 07-07-2013, 02:09 PM   #2
True 67
Re: new 72 truck doorw
what's the price for both doors?
True
True 67 is offline   Reply With Quote
Old 07-07-2013, 05:22 PM   #3
heehawracing
True
500.00 for both
Old 07-07-2013, 05:43 PM   #4
bertvert72
bertvert72's Avatar
Who made these doors?
Bret
Here's a link to my build
http://67-72chevytrucks.com/vboard/s...d.php?t=577889
bertvert72 is offline   Reply With Quote
Old 07-07-2013, 05:57 PM   #5
heehawracing
im not sure they came from LMC a few months ago im not sure who they use
Old 07-07-2013, 07:27 PM   #6
nlped
nlped's Avatar
What's the actual difference between the 67-71 & the '72 doors?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-07-2013, 07:47 PM   #7
CC69Rat
CC69Rat's Avatar
Door panels and there's a small indentation on the inner door by the wing window. The handle on the wing window drops down to the little dent on a the 72s.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-07-2013, 07:48 PM   #8
nlped
nlped's Avatar
Chad,
So could I use theses on my truck using my current hardware?
Carter
Old 07-07-2013, 07:55 PM   #9
CC69Rat
CC69Rat's Avatar
I think the window cranks and stuff are different for 72 than your 70-71 style.. someone correct me if I'm wrong.
Chad
Old 07-07-2013, 08:08 PM   #10
70LonghornCST
Moderator
70LonghornCST's Avatar
Correct, but technically, it is not the window cranks, that refers to the handles themselves. It is the the window relays inside of the doors that are different. Also, the door handle relays are different. The necks on the window and door relays stick out a tad farther on the 72 than on 68-71. However, unless you are using 72 door panels, window relays, and door relays, they will work perfectly. The 72 door panel is thicker. That is why there is a difference. In terms of the door itself, the only difference is the 68-71 doors lack the vent wing retaining hole for the long retaining screw. You would nee one to fill the hole, but could run them without. And I believe 67 doors have some slight differences from the 68-71, the exterior door handle mounting being one.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
Last edited by 70LonghornCST; 07-07-2013 at 08:13 PM. Reason: corrected information
70LonghornCST is offline   Reply With Quote
Old 07-07-2013, 08:08 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
68-72 use the same vent windows and handles. 67 are one year specific.
72 doors are the only different actual door frames...they have a hole under the vent window where a screw goes through to add extra strength at the vent window. No other difference other than 67 which has a slightly different pitch to the outer door handles so for the best possible fit you need to use 67 doors and handles...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 07-07-2013, 08:10 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
Lol....looks like we posted at the same time...and yes, if you're using 72 inner door panels you will need 72 specific door and window regulators as they stick out of the door further to compensate for the thicker door panels (not the door itself)
Old 07-15-2013, 10:20 PM   #13
heehawracing
ttt
Old 07-16-2013, 06:43 PM   #14
doghousecustoms
are you sure you cant ship them
doghousecustoms is offline   Reply With Quote
Old 07-17-2013, 11:14 AM   #15
nlped
nlped's Avatar
Offer made & accepted. I'll be over Saturday to pick 'em up. Thanks Man!
Carter
Old 07-24-2013, 05:07 PM   #16
nlped
nlped's Avatar
Finally went over to GA and met Kevin (HeeHawRacing) and picked up these doors. Great guy, great parts and no hassles. Thanks Kevin!
Carter
Old 07-25-2013, 10:57 AM   #17
heehawracing
thank you... nice talking to you.. and good luck with your truck
