Old 07-07-2013, 03:10 PM   #1
BurlyCrew
Can I change out axles on this original C-20 rearend to convert to 5 lug C-10?
Like the title says can I change out this C-20 8 lug rearend with 5 lug for this C-10 conversion I'm doing?
Where and who may sell axles, ring & pinion, etc to maintain the use of my axle housing and suspension?
Thanks guys! :-)
BurlyCrew is offline   Reply With Quote
Old 07-07-2013, 03:43 PM   #2
john
member #16
john's Avatar
Re: Can I change out axles on this original C-20 rearend to convert to 5 lug C-10?
Simply replace with a 12bolt 1971-1972 1/2 ton 5 lug rearend.
john is offline   Reply With Quote
Old 07-07-2013, 03:53 PM   #3
BurlyCrew
I've been looking haven't found anything near me yet, even a 6 lug rear I can do a swap on, anything 67-71 I believe, I hear the axles got wider in 72? Looking for narrower rearend...
Old 07-07-2013, 04:09 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
6-lug axles got wider in the 1970 model year,... and the 71-72 model year for 5-lug.
Look for a 67-69 housing for the early, narrower, rearend.
Keith
Convert to disc brakes.
Old 07-07-2013, 04:20 PM   #5
BurlyCrew
Ahh ok that's what I'm after then, thanks
Old 07-07-2013, 04:43 PM   #6
SS Tim
SS Tim's Avatar
The two axles are a completely different designs. The 8-lug is a full floating axle. That means the wheel is bolted to a hub that rides on two bearings that in turn ride on a housing extension (a spindle) that carries the weight. The axle is a seperate part that connects the hubs to the differential gears and provides drive force only. The 5-lug is a semi-floating axle. This means the wheel is attached directly to the end of the axle. The axle rides on a bearing inside the axle housing. In this case the axle mounts the wheel and carries all the loads in addition to drive force. A semi is considered a weaker design but is much cheaper, simpler and lighter. You really need to find a 5 or 6-lug semi-floating axle either a Chevy HO35 (12 bolt) or a much rarer Dana 44 found in some GM truck applicatons.
SS Tim is offline   Reply With Quote
Old 07-07-2013, 04:56 PM   #7
BurlyCrew
Have any idea where I might locate a housing to use ladder bars and all my suspension/width in same stock location?
Old 07-07-2013, 05:18 PM   #8
SS Tim
SS Tim's Avatar
Try Wes up at Classic Heartbeat.
