Vacuum Fitting Help needed
Ready to install some vacuum lines (tranny & power brakes) on my BB. Have a new Edelbrock Performer manifold and have discovered that nobody carries an aftermarket vacumn T set-up ready to go. What have you guys done to plumb up your vacumn lines? Any help appreciated.
Larry |
![]() Join Date: Jun 2002
salvage yard, most early 70's car's have the tee fittings. If you don't find one, let me know, I am sure our salvage yard has them
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
![]() Join Date: Sep 2001
I should be physically there helping you with this one.
![]() I use 1/4 and 3/8 brass fittings (1/4" to tranny; 3/8" to brake booster) from any NAPA or hardware store. I generally make a tee fitting that's small, out of the way, and somewhat adjustable. I don't put it together until I get the manifold and carb put in place with all the linkage (the vacuum hoses can turn out to be obtructed by the accel. linkage, etc.). Then I use the liquid teflon thread sealer you can get anywhere. Stay away from thread tape. I make the fitting first, then I apply the thread sealer to the fitting that goes into the intake. The thread sealer sets up in 24 hours, but you can make minute adjustments up to 12 hours after installing (I don't bother). It should dry to the touch in 1 hour. Then I use the stiffest hose I can get. Generally that means the hose has to have a fiber in it - like your radiator hoses.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
These guys carry the best selection of vacuum trees that I have ever found. Check them out!
Jim http://www.corvette-paragon.com/ |
