Old 07-07-2013, 04:08 PM   #1
6772chev
Need help on bags.
I picked up a 67 c10 short box and it has new bags 3gal tank all air line s ran to bags and up by valves. Four valves for each bag is in the glub box truck is c notched in the rear and has chopped a arms to reduce camber up front. I need help finding out how to build or buy a new steering shaft because its too low so it needs ujoints??? Not to sure and where to start with a compressor and switches I would like to run each bag individual I need help basically knowing how everything works and what to do with it is a 3 gal tank big enough ? Thanks if I could possibly get a number to call and just chat about it that would be awesome
6772chev is offline   Reply With Quote
Old 07-07-2013, 08:13 PM   #2
king-918
king-918's Avatar
Re: Need help on bags.
If I'm correct you have manual valves and you want electric? You can switch to an accuair like setup or just get 8 electric valves (4up /4down) and a prewired AVS box
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 07-08-2013, 01:47 AM   #3
andrewmp6
3 gallon tank is ok if you just wanna raise it to drive and drop it to park it,If you want to play with it a lot then you need a bigger tank and or compressors.How to wire a compressor and plumb the system http://www.s10forum.com/forum/f125/h...wiring-436980/ as far as the steering shaft take a picture of what your talking about.
andrewmp6 is offline   Reply With Quote
