Grille Repair
I used epoxy and narrow strips of thin aluminum sheet to patch together broken corners and other sections of my grille. I still have the lower left corner unsecured because I could not find the missing mounting tab. I will probably have to install some kind of big c clip from the backside to keep that side in place.
Re: Grille Repair
Ive used short strand glass and epoxy with some body filler to fix some myself.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: Grille Repair
Grill is looking good! What year is that grill and headlight bezels?
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
Re: Grille Repair
Stock setup for 1983 Silverado. I think 83 was a unique year.
Re: Grille Repair
Tried some ABS cement to replace a missing piece of plastic. You don't get the 30 second death grip the way you would with a pipe joint, but if you let the pieces set for 15 minutes or more you do seem to get a strong repair. Just need to sand it and paint now.
Not the best pictures but gives you the overall idea.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
