07-07-2013, 10:30 PM | #1 |
Brake Proportioning Valve Question
I have disk brake front and drum rear. Does this proportioning valve look correct? If not what would be the best replacement? Seems like a later model master cylinder, so not sure on the bolt pattern with 67-72 brake lines. What would be a good replacement (model numbers etc)? I would say I don't have great braking... would a new valve help that? Thanks for your input.
07-07-2013, 10:48 PM | #2 |
Re: Brake Proportioning Valve Question
That's a distribution block with low pressure warning switch. A prop valve is needed if your rear brakes lock up excessively before the front brakes, if the rears don't lock up first don't worry about it. Prop valve won't make any difference in your braking abilities other then the lock up issue.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
07-07-2013, 11:37 PM | #3 |
That distribution block was used for drum/drum applications. "For best results" you will want to invest in an actual proportioning valve designed for the GMs. They're actually not difficult to come by and they normally have the low pressure switch on them as well.
I had one from when I went to drums on the front. I know, crazy but with the loads I was pulling and the hills I was going over, I was warping rotors left and right. The rotors were not ready for me. :P
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
07-08-2013, 01:24 AM | #4 |
20' Daredevil (Ret)
Also, if your MC has equal-sized reservoirs, it's for drum/drum. MC for front discs will have a larger rear reservoir, which serves the calipers. The smaller front reservoir serves the rear drums. And IIRC, rear drums use a larger diameter brake line than the front brake lines (not sure but I think it's 1/4" rear and 3/16" front).
07-08-2013, 01:27 AM | #5 |
correct statement on the line size differences
toxic orange - just out of curiosity, is your truck 1/2 or 3/4 ton? Am assuming 1/2, but wanted to ask - MC line routing is different between a 1/2 and a 3/4 tonner. Yours is correct for a 1/2 ton truck, but Stocker is right - I'm not quite certain you have the correct master cyl. What year is your truck? As for what is correct? I'd go to Oreilly and ask for a 72 C10 (or 20 or whatever you have) MC and prop valve/distro block. Several vendors also sell the correct valve. Unfortunately, the correct stock part isn't cheap. Am sure CPP and a few other aftermarket vendors would offer a universal option, but I prefer stock personally (no real reason, just like a known quantity, I guess). |
07-08-2013, 06:58 PM | #6 |
Stocker:
My MC has a big reservoir in front and a small one in rear. Brake lines seem to be the same size. Likely a power brake conversion but I am not sure. Jocko: Truck is 1970 1/2 ton. It is a single bail MC and it seems that would not be the original, but not sure. Sounds like I for sure have a simple distribution block and likely need a proportioning valve. |
07-08-2013, 08:11 PM | #7 | |
07-08-2013, 08:28 PM | #8 | |
It is correct that you probably have a drum/drum conversion since it's ALL 1/4" lines. Technically, you'd need 3/16" lines for the front disks (the line that comes from the REAR port on the MC). You could buy a set of lines (front only, incl from prop valve to front junction block). And you need to have the proper distrib block/prob valve arrangement. Here are part numbers for you, if you were to order from LMC, for example (just an example, you can get them many places - I've purchased two 72 prop valves/distrib blocks from LMC, and have had no problems). Lines: OEM (non stainless) #34-5412 (includes the forward 1/4" lines that go to the rear junction block, so you might be able to buy the 3/16" only lines separately - or bend em yourself) http://www.lmctruck.com/icatalog/CB/full.aspx?Page=158 Prop Valve/Distrib block/pressure switch: You could use an adjustable one - #37-8559 http://www.lmctruck.com/icatalog/CB/full.aspx?page=155 or Factory-type 72 valve - #34-3200 http://www.lmctruck.com/icatalog/CB/full.aspx?Page=158 (and associated mounting hardware might be required) |
07-09-2013, 08:51 AM | #9 | |
